On Tuesday 78_f800crewcab4x4 and I checked out a ranch in Beatty Nevada for the F-600 they had sitting on their property. 78_f800crewcab4x4 needed the back doors for his bronco and steps for his 1960 F-800. The owner gave us a price to pick off as little or as much as we wanted so this is what we did...
Couldn't help but to laugh at this pic. I couldn't figure out if the guy was checking out something under the trailer or busted his *** getting off it.
Nice build too!
That is a cartwheel of joy over the new score.
Nice job guys. I would have liked to taken the whole truck!
Is the front floorpan/firewall the same as the light duty, or different?
Slightly dif.
Frame mounts are dif, floor pan as a whole is nearly identical, trans hump is dif. firewall is shared with 67-72, as is the dash. All other front clip mounting points are same.
That f600 crew cab was said to still run, rear brake was locked up and who knows what other problems there were. Very solid truck it was though.
