Help !!
I always save the big studs, square washer, and nuts from any manifolds I'm scrapping, so if you can't find a new one let me know. I will say, to get the studs out usually takes a large pipe wrench and a LOT of force, so the remains stuck in the manifold is going to be a problem. With the radiator out you'll have room to get a drill in there, but I doubt an easy-out will do anything but make things worse. Welding some rod to the remains may do the trick, so you have something to grab onto. The heat from welding usually helps too.
Is your intake a Ford aluminum manifold, or aftermarket? Is your generator bracket aluminum? I've never seen one that is, may be a Ford Canada thing, irrelevant to the problem, just curious.
The stud is pretty special, I would hold out for an original or NOS.
There are a fair number of diehard flathead guys in UK over on the Ford Barn, in particular "Mart" who is in Solihull. They will surely have parts and know good machine shops for the work. Might be worth joining over there to meet them.
I have an Offy AL 4 bbl manifold so along with an electric fan and shroud I used a different bracket that is lighter and attaches with bolts rather than a strap. It still used that single stud but it only supports the 100W alternator with the lighter bracket.
Hmmm... The shake down phase can be truly frustrating. My experience with our F1
is it just takes a while to get everything sorted out. On our first good drive all 4 brakes totally locked up
about a half mile from home on a busy multi-lane road..... grr... After a lot of trouble shooting ... our push rod from the pedal was
1/8 of an inch too long & kept pressure on the pedal. My engine ate the first set of engine rods because the builder didn't use case hardened ones...
Hang in there. I know it looks bad but you can get it cleaned up & working again. Hop back up on that horse.....
Ben in Austin
1950 F1 (3511W/AOD)
The clip is from the Ford Parts CD, https://www.hipoparts.com/1948-56-fo...ts-catalog-cd/. Very useful and for the price a real bargain.
I don't know of anyone making the studs, but I'm sure someone in UK has some spares.
These bolts do not hold weight, they tighten a bracket to a mount for a friction type fit. Torque is the main over-riding stress on the bolt.
It looks to me like a torque failure (twisting - from over-tightening at some point in its life), although what does it matter now, and I cannot see that much from pic.
Below is a link to eBay (US) for one of these that recently sold for a great price.
There is a current one for sale on eBay (US), priced high (relatively), but is only the "nut" part - not complete. You need nut and stud.
I notice you don't have a lock washer, and neither does mine, I never thought of it, But the ones for sale all have lock washers.
Any advice from you all out there for our UK friend and me and any others of us who are not using lock washers??
Oh, and great job, Suffolk, in finding the part on the road! It sure helps when you have an example of the strange looking part you are trying to find! Can you imagine all of us trying to describe it to you without a picture!
https://www.ebay.com/itm/Ford-Flathe...p2047675.l2557
I've found them with lock washers, and without. With the fine threads and long nut engagement, I don't think the lockwasher is needed. It can make the adjusting of the belt tension an even worse job than it already is. The big nut gets tightened to 55 - 70 ft-lbs.
As for some forensics on Suffolk's stud: I got to thinking they probably pulled that out of a cast iron manifold, using way more torque than the 55-70 lbs recommended, because it was like welded in there after 70 years.. So the stud became over-stressed while torquing it out, resulting in strain (engineering definition) in the top threads near entry to manifold. Then, to add insult to injury, same thing happened perhaps on installation (over torqued again) = more strain in weakened area. So now you have a necked down stud that is brittle due to strain hardening. if Suffolk was able to get that stud fragment out of his manifold in one piece ( which I think is going to be not so easy), I am betting we would see necking (engineering definition again) just a couple of threads before where the threads transition to a shoulder. He might even see it (likely very subtle) on the piece he recovered from the road. It would not take much necking to cause a failure. The failure would be a stress fracture due to brittleness.
Anyway, lesson is that if installing an old stud, check for necking. (OK, I'm ready for the necking jokes now)
Is your "generator" actually an alternator? It appears to be different from the generators I'm used to seeing, although export models sometimes used different brands than domestic.
