Steering gear box
Old May 6, 2018 | 09:33 AM
Kelyn Brown's Avatar
Kelyn Brown
Steering gear box
Anyone know where I can get a Steering gear box for 1953 - 1956 F600
Old May 6, 2018 | 10:41 AM
Indybeer's Avatar
Indybeer
Not sure if you are looking for rebuilt or used, but Mid Fifty has rebuilt steering boxes as well as rebuild kits if you want to do your own.
Old May 6, 2018 | 11:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year is the truck? 1953/55 is different than 1956.
Plus, there two different cabs, Conventional Cab and Cab Forward. Cab Forward uses a different steering gear
TCAA-3504-A .. Steering Gear Box: 1953/55 F350/500/600 Conventional Cab.
B6Y-3504-A .. Steering Gear Box: 1956 F350/500/600 Conventional Cab.
Note: The steering shaft and worm & the sector shaft shown in post #2 are for F100/250 // F350/600 is different.
Old May 6, 2018 | 12:41 PM
Indybeer's Avatar
Indybeer
Ok didn't know they were different. the Parts and Acc catalog I looked at doesn't show 53-56 as different. F600 (model TH) I assumed conventional cab.
Old May 6, 2018 | 08:17 PM
NumberDummy
What in the world???
The upper chart only defines what series trucks used what parts catalog symbols, has NOTHING to do with steering gears!
Parts catalog symbol: C = F100 / D = F250 / Y = F350 / T = F500 / TH = F600 / W = C500 Cab Forward / WH = C600 Cab Forward and etc.
Lower is a generic pic, does not mean all these steering gears are the same!
Pic = Scroll down to 3504 Steering Gear application chart:
Old May 7, 2018 | 06:16 AM
BlueOvalRage's Avatar
BlueOvalRage
I don’t know the ‘53-‘56 stuff nearly as well as the first generation F-series parts, but I’m reasonably certain that the difference between the ‘53-‘55 steering gear and the ‘56 units is the length of the worm gear shaft and consequently the steering column due to the dash design change. The rest of the box is the same from ‘53 through ‘56 for the corresponding truck sizes.
EDIT: Duh! It says as much right there on the Midfifty catalog page in the 2nd post.
Old May 7, 2018 | 07:53 AM
Kelyn Brown
1954 F600 steering gear
Guys thanks for the feedback
i am wondering since I do not do heavy work with this truck and I have got o
a set 19.5 1 piece rims with radials if I can install one of the power steering gears boxes that are on Mid Fiftey’s web site
Dustbunny1990
Mar 12, 2018 01:17 AM
winginit
Nov 9, 2014 11:21 AM
Fireman_dave
Oct 20, 2011 06:06 AM
WYO92350
Nov 15, 2006 08:14 PM
