Starter Replacement
Old May 14, 2018 | 01:22 PM
  #31
1TonBasecamp's Avatar
1TonBasecamp
Originally Posted by wwchatt
I will have the battery tested to see if that may be the issue. Just noticed the date code on it is Aug 2014 so it is good possibility its dead.
Or it's just "dead" as in discharged. If you don't have a charger then maybe the they'll charge it for you to test. It has to be fully charged for testing anyway, so that's probably part of the service.
Do you have a volt-meter? Did you check the state of charge?
I did have a new cable running from the running from the solenoid down to the starter but I was trying the old one again just to eliminate some of the new parts as being faulty. The new cable is labeled as 4 gauge.
Excellent. And a good idea to verify those aspects of the old one.
I will definitely consider doing the red cables for positive or at least labeling them in some way to help avoid an oops. Maybe wrap towards each end with some red tape of some sort. (I know, it would be ugly but for now just looking a functional vehicle not necessarily a good looking one).
Red tape is a start. But an even better solution, especially for that old one with the exposed contact point is heavy duty shrink tubing with sealant. Good stuff and a good idea for any battery cable frankly.
I actually like the store bought full crimp type like you have coming from the battery. The lugs could be improved, but it's hard to beat their crimp method. However, I always put some form of shrink tubing on the ends with the crimp. Slide one over that's just big enough, shrink it down and not only to you have a good connection, but now you have one that will stay good and resist corrosion for even longer.
I did notice that the PO cranked down on one of the mounting screws and has stripped out the hole and in the fenderwell so that the screw just spins. Would an acceptable fix be to either use a slightly larger screw or to find a bolt/nut/washer to replace that screw?
Probably 70% of our trucks have that issue. Not sure if it's PO aggressiveness necessarily, or just the nature of the beast. Thin sheet metal, even with nicely stamped holes, is not always the longest lived thread method.
A larger screw is great if it works. I've had good luck, and some not so good luck doing that. But it's easier for future maintenance than a nut-n-bolt setup. However, if the larger screw won't hold, the nut-n-bolt is a winner.
Paul
Old May 14, 2018 | 01:24 PM
  #32
1TonBasecamp
Sorry, didn't see the last two posts before I replied.
This time though I think it was a forum issue. I clicked on the new page, so the new posts from 4 and 5 hours ago should have showed up clearly. When I hit quick-reply for mine, instead of the normal viewing of my post, it took me back to the top of the page and sat there.
When I scrolled down I saw your two posts, but not mine! So I hit send again (because I learned long ago to copy-n-paste before sending!) and now I see it.
So if mine shows up twice, that's what happened.
Forum-jabber over. Now back to our regularly scheduled battery talk...
Paul
Old May 14, 2018 | 03:28 PM
  #33
wwchatt's Avatar
wwchatt
Had a few minutes to check voltage on the battery. It’s fluctuates between 10 and 12 volts.
When I measure from the negative battery terminal to the positive side of the solenoid relay I get 12ish volts. When I test from positive side of relay to any of the other 3 terminals on the relay I get 12ish volts.
Does this all sound about right or am I missing something?
Old May 14, 2018 | 03:50 PM
  #34
Tedster9's Avatar
Tedster9
10 and 12 volts is a huge swing for a car battery. Are you measuring during cranking, or?
Even a few tenths measurement is important. A fully charged sealed maintenance free battery at rest measures 12.80 volts at 77° F. 12.00 volts may not even be enough to crank over the starter in cold below zero weather. So we're really only talking just over half a volt between 100% and Dead.
Old May 14, 2018 | 04:23 PM
  #35
wwchatt's Avatar
wwchatt
I was measuring with nothing turned on. Not cranking. Air temp about 90 degrees. Just holding the two probes against the battery terminals the meter would jump mostly between 10 and 11 but it would go a bit higher than 11. I would hold the probes to measure for about 10-15 seconds.
Old May 14, 2018 | 04:44 PM
  #36
Tedster9's Avatar
Tedster9
OK. That's not a very good sign for the battery but I haven't been keeping up on this thread. Did you charge it up overnight?
Old May 14, 2018 | 07:35 PM
  #37
Filthy Beast's Avatar
Filthy Beast
Why is that? Too much coffee for you today? Voltage fluctuation readings like that means something is not right....an intermittent parasitic drain.....as you well know. Are you measuring from post to post and cable to cable?
Sum Ding Wong....and why are you measuring from the BATT NEG to the (+) solenoid? Yes, I know the POS (+) BATT terminal goes there but that's not what counts...(very much) Measure the battery post to post and then cable to cable. Cable to cable measurements will tell you how the connections are....not just an old fart asking you to do something redundant.
And you should have ZERO voltage on the the other three solenoid terminals when/if the IGNITION SWITCH is OFF.....There's your battery drain.....the solenoid. Have you whacked that bad boy like I had asked?
Old May 14, 2018 | 08:27 PM
  #38
colonelmustard's Avatar
colonelmustard
I may have missed it but have you put a hot battery out of a running driving car in it and see what happens? 10-11 volts ain`t gonna cut it. Just trying to help.
Old May 14, 2018 | 09:15 PM
  #39
wwchatt's Avatar
wwchatt
Ok, went back out tonight and took measurements again.
With no key turned, no lights on:
From post to post on the battery, a steady 12.47
Between the two sides post on the solenoid, a steady 12.4
From positive post on solenoid to any other of the other 3 posts on the solenoid/relay 12.4
With key turned just to the run position(one position to the right, but not held in the starting position):
(positive battery cable started to get a bit warm with key in this position)
From post to post on the battery, a steady 11.90
Between two side posts on the solenoid, a steady 8.96
And yes, I gave the relay a couple of good whacks with a rubber screwdriver. I did not want to break anything so I may not have hit it hard enough. Just an fyi, but this is the Motorcraft brand solenoid/relay with the D2AF-11450-AA number across the top.
no, I have not tried any other battery yet or tested/charged the one I have. As soon as I get more than a few minutes I will take this one to have it checked out.
Great suggestions everyone. Many thanks!
Old May 14, 2018 | 09:50 PM
  #40
meangreen92's Avatar
meangreen92
You can rule out the solenoid by disconnecting the cable to the starter, and powering the "S" post to see if you hear it click. If it clicks, then you can connect a light bulb or volt meter to to the starter cable lug to verify that current is passing and that the circuit is closed.
Old May 15, 2018 | 08:46 PM
  #41
wwchatt's Avatar
wwchatt
Ok guys, went out tonight and tried things again. Still getting 12.4 on the battery and the cables.
When turning the key, with the OLD relay hooked up i get rapid clicks from the relay but truck still wont start and the dome light dims but does not go all the way off
When turning the key with the NEW relay hooked up I get a single loud click(clunk) sound but the truck wont start and the dome light goes off.
Still have not had the battery checked. I have no commitments after work tomorrow so hopefully that can be done then.
Old May 15, 2018 | 09:13 PM
  #42
Filthy Beast
Ok....have you tried jumping the solenoid? If you've tried it before, disregard that question and the following description:
Jump a wire from the BATT (+) on the solenoid to the "S" terminal......she should at least turn over as long as you hold the jumper wire in place.
If that works, you can leave the key in RUN and jump her the same way again....she will start then......if all things are fine in Denmark..........
Old May 15, 2018 | 09:46 PM
  #43
wwchatt's Avatar
wwchatt
So I do not make things worse than they are, let me clarify--- do I leave the cable going from the pos batt post to the solenoid while I am jumping the solenoid? Also, when trying to just get the engine to turn over is the key turned at all?
Thanks
EDIT: went ahead and gave it a shot. Left everything connected but ran a jumper from the batt to the S terminal. The solenoid clicked,clanked, clunked etc but starter did nothing. So did I get bad starter or is there something else going on?
Old May 15, 2018 | 09:58 PM
  #44
Filthy Beast
The engine *should* turn over for as long as you hold a jumper wire from the BATT (+) to the "S" solenoid terminal. The moment you let go (off either terminal) the engine will croak. ALL THIS IS DONE WITH THE KEY OFF.........
Also, when trying to just get the engine to turn over is the key turned at all? Thanks
Absolutely, turn the key to RUN and jump the solenoid in the same fashion and if things are cool in Amsterdam, she'll run. Once she's running, you better relieve the jumper from its position.
Now go back and read post # 42. Dn't blame you for wanting to be precise.....
Old May 15, 2018 | 10:26 PM
  #45
Filthy Beast
Thanks
Hmmm That's a basic symptom of a battery not having the poop to turn over an engine. Not having enough juice to engage the solenoid's contacts to turn the starter.
You could by pass the solenoid altogether and put BATT voltage right to the starter wire terminal and see what happens. If the starter doesn't at least fart a few times, check the cables for resistance...... you might have to pull the starter and bench test it......and make sure the battery has a full charge...
Have you had a chance to get the battery load tested yet?
