Rear leaf spring torque info
Old May 5, 2018 | 06:58 AM
nwashburn21's Avatar
nwashburn21
Does anyone have the torque specs for the 2017-2018 srw f250/f350 rear axle- leaf springs, u-bolts, shocks, etc? Thanks in advance!
Old May 5, 2018 | 09:06 AM
briangp's Avatar
briangp
Since no one is answering.... I would reference a previous year, where the knowledge is abundant. I would be impressed if the torque values changes.
Even if they did, you'll be safe.
Old May 5, 2018 | 09:20 AM
nwashburn21
Ok. Well I was afraid something changed with them with the new frame and beefier axle options.
Old May 5, 2018 | 09:30 AM
VA13FX4's Avatar
VA13FX4
There are a couple posts for lowering the rear end where someone posted the torque specs.
Old May 5, 2018 | 09:47 AM
Towerhog's Avatar
Towerhog
Upper Shock Nut......52 ftlbs
Lower shock Bolt/Nut......111 ftlbs
Spring to Frame Bolt/Nut (front)......490 ftlbs
Spring to Shackle/Shackle to Frame Bolt/Nut......173 ftlbs
Ubolts F250/350 Single Wheel Cross Pattern:
1st Pass......48 ftlbs
2nd Pass......96 ftlbs
3rd Pass......148 ftlbs
4th Pass......195 ftlbs
F350 Dual Wheels Cross Patern:
1st Pass......74 ftlbs
2nd Pass......148 ftlbs
3rd Pass......221 ftlbs
4th Pass......295 ftlbs
Old May 5, 2018 | 09:51 AM
briangp's Avatar
briangp
There ya go. ^^^
Honestly from an engineering perspective, torque values are based on the hardware, not the parts. You can have all beefier axles if you want, but if it's the same U bolts/nuts holding it on, the torque values won't change.
Old May 5, 2018 | 10:18 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
"Tight as hell" is usually my default torque setting on suspension components
Old May 5, 2018 | 10:27 AM
nwashburn21
Originally Posted by briangp
There ya go. ^^^
Yeah, I figured with larger axles, etc, there would be larger hardware, I guess was my point. Didn't want to follow old torque specs if that were the case.
Old May 5, 2018 | 10:28 AM
nwashburn21
Thanks for the info!!
'94IDITurbo7.3
25
May 14, 2014 08:38 AM
spindlebox
Oct 6, 2013 07:49 PM
kgwld1
Feb 17, 2007 05:31 PM
bluebird
Aug 30, 2006 07:22 AM
