Crank time until start
Old May 3, 2018 | 02:21 PM
microbc's Avatar
microbc
I have a question regarding the crank time until start.
My truck has always taken 3.5 to 4 seconds to start either in the morning or after sitting for a few hours.
I always accepted that as normal.
New 6.0 starter last summer, two new batteries last fall
Recently had a bunch of work done, all new injectors, new oil cooler, new standpipes and dummy plugs, new IPR valve, cleaned turbo and ICP valve.
After all the repairs my truck takes the exact same 3.5 to 4 seconds to start.
I have read so many posts of trucks that fire in <2 seconds.
What would account for the "longer" crank time on my truck both originally and after all the repairs?
Thanks,
​​​​​​​Art
Old May 3, 2018 | 02:36 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Time that it takes for Cam/Crank or FICM sync maybe? You could chart all the PIDs required for starting in IDS/AE/ForScan and see if one is tied to when the engine actually starts, but IMO that's a lot of effort searching for a problem that might not really be an issue at all. Under five seconds is what keeps getting tossed around as "normal", so if your HPO PIDs read fine and it's otherwise all normal, just might be a quirk in your engine that makes it be that way.
Old May 3, 2018 | 04:24 PM
microbc's Avatar
microbc
Hi texastech_diesel,
I forgot to mention that a new cam/crank sensor was installed when all the work was done.
I'm jealous of the guys with the super fast starts! lol!
I don't think it is a problem I was just curious as to why some trucks fire in <2 seconds and other trucks, even with a bunch of new parts see no change in their "slower" starts.
Thanks!
Art
Old May 3, 2018 | 05:22 PM
mcali2's Avatar
mcali2
I replaced a bunch of stuff too. No change in starts.
Old May 3, 2018 | 08:03 PM
navistarnut's Avatar
navistarnut
Thanks!
Art
Try a little cetane booster like Ford PM 22 in the tank, see if it makes a difference.
Nothing wrong with those times Art. The farm I work at on the side has several 6.0's,one of them is a slower starter compared to the other two.
Old May 4, 2018 | 12:41 AM
vfelix702's Avatar
vfelix702
try a 6.4 starter alot of guys o that also including myself
Old May 4, 2018 | 07:22 AM
53jimc's Avatar
53jimc
Yep, I did the 6.4 strter upgrade. You'd be amazed at the difference, starts much faster. $83 bucks from DB electrical, no core charge. (no, I don't work for them and they haven't given me anything for saying that, lol)
Getting the thing on/off is a real bear, imho, but worth it.
Old May 4, 2018 | 01:52 PM
DawnPatrol's Avatar
DawnPatrol
i have always had around 1 to 1 1/2 second starts. Ever since I purchased it I have religiously used Amsoil Diesel additive, along with fresh batteries and a new starter about a year ago
engine turns over quick and fires right up
Alan from San Diego
Old May 4, 2018 | 03:38 PM
On1wheel01's Avatar
On1wheel01
Mine fires up right at 2 seconds. 139k miles
Old May 4, 2018 | 08:21 PM
IHateCommieCars's Avatar
IHateCommieCars
I guess you can watch the RPM and IPC numbers on your Scanguage to make sure you got RPMs and oil pressure.
Old May 5, 2018 | 12:04 AM
Euroman's Avatar
Euroman
Mines always within 2 secs, use synthetic oil and premium grade fuel. Always wait 4-5 secs after the light goes out before cranking as that seems to make a difference - quicker to fire up and cleaner idle straight after
Old May 5, 2018 | 01:08 AM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
It can be standpipes drain down, or LPOP is a little slow I think poppit in filter can do it. Also a ICP thing the list is pretty long.
A bit of salt while I'm here too 1-1.5 seconds and mines lit off.. Also 6.4 starter along with a big cable upgrade pushing lots of energy around.
But a 3-4 second grind is not anything to worry about.
Carolina Rig
Nov 1, 2018 08:49 PM
Redneckrican87
Feb 27, 2017 07:57 PM
fordf150guy
Dec 21, 2016 06:31 AM
"Phatman"
May 31, 2016 08:16 AM
dusred
Dec 1, 2009 05:27 PM
