Fuel Pump Woes
Old May 3, 2018 | 12:36 PM
dougoutdoug's Avatar
dougoutdoug
Fuel Pump Woes
This will be an odd post for this forum. Hope you can help.
A friend of mine recently purchased a boat that was powered by a 6L Power Stroke diesel engine. Unfortunately he forgot to turn on the bilge pump and the boat partially sank. He had to replace the entire engine but he did so using a gas engine instead of a diesel engine. He had the fuel tank replaced with the same one he had before. The fuel pump in the system is a Racor PFP58054, which is listed as a diesel pump. But he's using it with a gasoline engine.
Over the past year he has had to replace the fuel pump 6 times and he can't figure out why it keeps failing. I suspect it's because the pump wasn't made to pump gasoline. But I don't really know the answer so I'm wondering if anyone here knows what happens if the Racor PFP58054 is used in a gas system, not a diesel system. Can you help?
mark460
Jan 14, 2015 02:18 PM
svtcobra041
31
Jan 9, 2010 06:41 AM
indebt
22
Jun 16, 2007 11:01 PM
rickgthf
Electrical Systems/Wiring
Nov 18, 2006 08:00 PM
thesprocket26
Feb 9, 2006 10:17 PM
