Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.
Bakflip F1 problem - Anyone else?
Old May 2, 2018 | 08:41 AM
Grand Illusion's Avatar
Grand Illusion
Trailering
I just installed a Bakflip F1 on my 17 F350 Dually (8' bed). I'm just curious... has anyone else??? And are you having any problems with general fit? Mine only covers about 1/4 inch of the tailgate (not enough for the water seals to even touch the gate) and a 1/2 inch of the front bed rail (at best). The biggest problem I have, though is that as I fold the cover, after the third fold (the one just before the final fold that stands the cover against the back window), there is a significant amount of “bind” on the cover from the latches against the top of the final panel, so much so that it holds the front of the folded cover an inch or so above the panel it should be resting on. I took a photo of it, and sent in a rough drawing of the problem to Bak Industries and their support people told me this was absolutely normal. I believe the weight from the folded top not resting against the rest of the top is going to damage the latches and/or the cover where this levered pressure is. Anyone else seeing this problem? Oh, and yes, it's dirty. Farming has started and so has the dirt rolling off of the fields.
Old May 5, 2018 | 07:08 PM
Sportscape's Avatar
Sportscape
1st My opinion BAK sucks! Mine was bad, the dealer fought with them until they finally replaced it,they replacement was worse. If you are lucky enough to get a hold of customer service they will explain how great they are and you must be an idiot because you expect an $800 item to work.
If I'm understanding correctly that is how mine was new,after a while it stretches and sags down. Mine is on an F150 but there is not much overlap for the water seal, and it doesn't seal well. With age those seals stretch and shrink and seal even worse. My cover, now 3 years old, is faded discolored and just bad looking, it provides little water seal and is about useless, other than keeping my stuff out of sight.
So my suggestion if you are within the time limit and can, I would return it. The only other option is live with it and try to warn others about what a piece of junk they are.
Old May 13, 2018 | 07:55 PM
Beechkid's Avatar
Beechkid
This is what (and why) I did on my Mark LT.
https://www.ford-trucks.com/forums/8...bed-cover.html
and a pic of the bedcover from the top
https://www.ford-trucks.com/g/picture/815249
Freedom1955
2015 - 2020 F150
Jul 16, 2016 07:45 PM
MCDavis
2004 - 2008 F150
17
Jun 15, 2016 10:38 AM
d445
2009 - 2014 F150
27
Feb 3, 2010 10:30 AM
mcjones44us
Nov 30, 2008 01:39 PM
MattyNJ
Appearance & Dress-Up
Nov 29, 2007 12:43 PM
