96 5.8l Speedometer
Old May 22, 2018 | 02:38 PM
JimWithAnOBS's Avatar
JimWithAnOBS
Originally Posted by subford
If it is jumping from between 0 and 20 with the truck parked I would not do anything to the rear end other then maybe unplugging the VSS at the rear end.
Also leave the RABS module unplugged.
See if it still does it.
If so you either have a bad power connection or ground to the PSOM or a bad new PSOM.
Did the old PSOM do the same thing?
If yes I would look at the power and grounds.
Thanks, will unplug the ABS module and test it out. Then just have to find the grounds.
Old May 25, 2018 | 12:44 PM
johnstonmatt77's Avatar
johnstonmatt77
Hey guys, I’ve been having similar issues but I’ve narrowed it down to the PSOM or the ABS module. I have a 96 F150 and the speedo is jumping around a lot and my brakes will pulsate every now and then. I’ve changed the VSS, checked the rings in the back, the only thing I didn’t replace yet is the ABS module behind the glovebox. I’m going to go get a new PSOM at a junkyard either today or tomorrow. Is there any way to swap the odometer from the old to the new so I can keep the mileage? I took my psom off and couldn’t really see a way to swap it without breaking anything. Has anyone ever done this before?
Old May 25, 2018 | 12:59 PM
subford's Avatar
subford
There are two ways to keep your mileage.
One way is to remover the EEPROM from the old board and install it on the new board by either soldering it in or solder a socket in and plug the old EEPROM in it.
The other way is to copy the information out of your old boards EEPROM and burn it into the EEPROM in the new board. No soldering required and no power hooked up to the boards while copying.
Old May 25, 2018 | 01:26 PM
johnstonmatt77
Here’s the back of it. How would I access the EEPROM to switch it? (Second option)
Old May 25, 2018 | 02:03 PM
subford's Avatar
subford
Just take all of the gauges out of the front and then unscrew the PSOM from the Speedometer.
The PSOM:
Attachment 279742
Old May 25, 2018 | 05:50 PM
JimWithAnOBS
Wish I could say if fixing the ground worked or not, pulled the panel in front of the passenger side door and found a somewhat large mud dauber nest on top of the ground wire. Removed the nest, cleaned up the contacts with a wire brush and reinstalled the bolt. But when I tried to start it again, it didn't want to start. When it finally started the idle was really rough and it was puffing white/blue smoke from the exhaust and kept dying. Looks like a head gasket now. Gonna be a while til I really get it fixed.
Old May 26, 2018 | 10:42 AM
johnstonmatt77
Underneath the passenger side of the dashboard there’s a 3 ring connector that I think is the RABS data link connector. Is this what is used when trying to get RABS codes or can I hook u a code reader to the OBD2 port and get the codes? And is there an adapter that is needed to connect to the RABS port?
deljac
Jan 10, 2016 07:12 PM
joaayc
Jan 13, 2015 07:51 PM
daniel's truck
24
Feb 11, 2012 07:10 PM
MaryfPoppins
1978 - 1996 Big Bronco
16
Jun 29, 2009 11:43 PM
Kemicalburns
Aug 22, 2007 12:40 PM
