Po500
Old Jan 9, 2016 | 03:09 PM
deljac's Avatar
deljac
Po500
I have this code coming up on my 96 f150 5.8 e4od.
My speedometer started acting up then my trans and error.3 came across on my odometer and my o/d button started flashing. I have reset my codes and I've replaced the vss with one from my other truck so I know it works. And I got the error.3 to go away by recalibrating my Palm
Oh and I unhooked my battery for 1/2 hr. I tried driving it and my speedometer is still jumping around. Anyone had this problem and what did you do to fix it. Oh and I've checked my wiring at the rear end and all looks good
Old Jan 9, 2016 | 03:15 PM
Phy's Avatar
Phy
Pull the VSS out and clean it. It may be that easy...
Old Jan 9, 2016 | 03:33 PM
deljac's Avatar
deljac
I cleaned it when I put it in out of my other truck
Old Jan 10, 2016 | 08:00 AM
deljac's Avatar
deljac
Do I need to drive it for a few miles for it to relearn
Old Jan 10, 2016 | 08:20 AM
Eddiec1564's Avatar
Eddiec1564
With a Error.3 showing in the odo, the PSOM(speedometer) is bad due to corrupt EEPROM on the PSOM.
Best to find another PSOM from the junk yard and reprogram the pinion ratio for your truck, but the mileage will not be the same as its's stored in the PSOM's eeprom.
Old Jan 10, 2016 | 11:52 AM
deljac's Avatar
deljac
I cleared the error.3 when I recalibrated the psom. And as far as getting a new one that's a long shot since mines a 96 and as far as I've learned on here 96 is a 1 yr only
Old Jan 10, 2016 | 12:58 PM
Eddiec1564's Avatar
Eddiec1564
Any E-series AND F-series speedo(psom) from 94 and up will work. Just change out the speedo head from the cluster. 93 and older will work but had wobble issues in needle in some cases.
Old Jan 10, 2016 | 01:52 PM
deljac's Avatar
deljac
Wow thank you I have one from a 95 I will give it a try
Old Jan 10, 2016 | 06:18 PM
deljac's Avatar
deljac
Eddiec1564. Thanks. I changed it out and its working great now. I appreciate the help
Old Jan 10, 2016 | 07:12 PM
Eddiec1564's Avatar
Eddiec1564
Good to hear, just get another PSOM and hope the milage is close to what's in your truck and reprogram the pinion ratio too.
JimWithAnOBS
21
May 26, 2018 10:42 AM
erupert66
Oct 4, 2013 04:19 PM
buscherautollc
16
Dec 15, 2012 03:38 PM
daniel's truck
24
Feb 11, 2012 07:10 PM
Playing_Tough
Sep 26, 2006 08:19 AM
