Can I replace the shift indicator cable? Mine wasn't quite right so I took the cover off the column to adjust it. After a quick adjustment it seemed to work better, but was not working 100%. It looks like the sheathing on the cable broke, and someone tried to repair it with electrical tape. I put it all back together and tested it and it seemed to work better, but not perfect. Then on a short trip to the farm supply I shifted into D and I heard a loud crack, now the indicator doesn't move.
EOTZ-7A110-B .. Shift Indicator Cable / Obsolete
1980/86 F100/350 & Bronco C4/C5/C6.
METTER FORD in Metter GA has 1 = 800-972-3388 (@ $78.85).
RPN PARTS in Erie PA has 9 = 888-864-9305.
GREEN SALES CO. in Cincinnati OH has 9 = 800-543-4959.
There's one on ebay: $100.00 (listed as E0TZ-7A110-B)
NumberDummy to the rescue again! Thanks a bunch! Is this info you have all public stuff or do you have super secret rabbit ears implanted in your head?!
