04 Excursion 6.0 shudders when accelerating
Old Apr 30, 2018 | 10:12 AM
Frank L. Chaput's Avatar
Frank L. Chaput
Truck runs great but it kind of bucks or shudders when you accelerate. If you back of of it or accelerate it goes away. So when it starts to shudder if you jump on it it will stop or I can just take my foot off the accelerator and it stops. It driving me crazy.
Does anybody have any idea what could me causing this?
Old Apr 30, 2018 | 10:54 AM
Stewart_H's Avatar
Stewart_H
Moved to the 6.0L PSD forum.
Stewart
Old Apr 30, 2018 | 11:07 AM
navistarnut's Avatar
navistarnut
What are you using to monitor data live?
Do you have any codes?
Old Apr 30, 2018 | 11:45 AM
Frank L. Chaput
NO codes. No check engine light.
Old Apr 30, 2018 | 12:11 PM
mcali2's Avatar
mcali2
Maybe a U joint?
Old Apr 30, 2018 | 01:38 PM
navistarnut
Originally Posted by mcali2
Maybe a U joint?
Or something else in the drive train. Sounds like it's drive train related to me, possibly torque converter shudder.
Old Apr 30, 2018 | 03:41 PM
Sparky83's Avatar
Sparky83
just curious but does it only do it like at specific times in the trucks heat cycle?? for example when you first jump in the truck after its sat awhile and everythings still cold, will it do it then but not later when everythings warmed up? or only after its warmed up does it start? or does it not matter at all on that?
sometimes that can make a difference in figuring out where a problem might be.
Old Apr 30, 2018 | 05:58 PM
Frank L. Chaput
It does when its cold less once it warms up. I replaced every component of the front end to include rotors , calipers, hubs, hub bearing, seals and all steering components. Its not a suspension thing I know for sure. When I drive it it will start bucking between 45 and 60 . Back of the fuel it stops jump on it it stops. But it feels really jumpy in that range.
Old Apr 30, 2018 | 11:46 PM
mcali2's Avatar
mcali2
Could a faulty TPS do this?
Old May 2, 2018 | 02:59 PM
OneCylinder's Avatar
OneCylinder
I'm experiancing the same or simular problem. Had my mech diagnose it yesterday, with scan tool. the problem was replicated but no codes found. Will probably drop the fuel tank friday.
The truck in the video is a 7.3 but the concept may apply. The symptoms are like mine and maybe yours too. Mine shudders then looses power when at highway speed especially if I accelerate in high gear. Around town it runs fine.
Old May 2, 2018 | 04:29 PM
bismic's Avatar
bismic
Have you tried running w/ the ICP disconnected? Probably a long shot, but it is cheap to try.
Old May 2, 2018 | 04:38 PM
navistarnut
Hope his ICP is easy to access
It's an 04, and an Ex to boot
Mike Brackins
May 21, 2016 08:42 PM
davefrommd
Sep 15, 2015 10:16 AM
oldflotsam
Aug 28, 2011 05:19 PM
lombardo96
Feb 1, 2007 07:50 PM
