Rear ABS question
Old Apr 30, 2018 | 08:37 AM
f150crewcab's Avatar
f150crewcab
Rear ABS question
1995 F-250 XL 5.8L E4OD. 54K miles (yes, that's all). Had to hit brakes hard yesterday to avoid accident and rear tires locked and slid about 30 feet. Avoided accident though.
Why didn't the Rear ABS work? No CL light. No "Rear ABS Light," except when I engage parking brake. Replace rear ABS sensor? What else should I test/replace? Thanks in advance.
The truck was my great Uncle's farm truck and I acquired it from his estate about 3 months ago. He was meticulous with maintenance.
Old Apr 30, 2018 | 03:34 PM
tjc transport's Avatar
tjc transport
i ain't rite
the RABS on these trucks was marginal at best, and a lot of times it did not work from new.
all of my trucks had it disabled and bypassed before there was 100 miles on the speedometer.
Old Apr 30, 2018 | 04:18 PM
rla2005's Avatar
rla2005
We debate the RABS effectiveness topic about every other month. A quick search will yield the results.
FYI...if there was an issue with the RABS system it will not trigger a Check Engine Light (CEL). There is no connection between the RABS system and the powertrain control computer.
My experience with three OBS trucks was positive for how the RABS reacted under various conditions. My old 1992 F350 never triggered an ABS light, but I knew it was not working. I replaced the RABS hydraulic control module located on the driver side frame rail as I was repairing other issues related to dragging rear brakes and a soft pedal. After replacing that piece the RABS operated just like it did on my two previous 1993 Lightnings.
Another observation per your comment: " No "Rear ABS Light," except when I engage parking brake." When engaging the parking brake you should get the red Brake light, not the yellow ABS light.
Old Apr 30, 2018 | 04:47 PM
Scndsin's Avatar
Scndsin
Originally Posted by f150crewcab
...The truck was my great Uncle's farm truck and I acquired it from his estate about 3 months ago...
Chances are, the lock up is from sitting & not the RABS.
These drums are not the best after sitting for any length of time.
If not driven on a daily basis, they'll lock in a heartbeat.
Old Apr 30, 2018 | 04:58 PM
rla2005's Avatar
rla2005
Plenty of reasons for why the rear brakes locked up even beyond a component failure like I had. Best bet for any new to you vehicle is to remove the rear drums to inspect the shoes, hardware and axle seals. Highly suggest to give the front calipers, pads and wheel bearings/seals a good inspection as well.
Old Apr 30, 2018 | 06:42 PM
f150crewcab
Thanks guys. Good advice, as usual. From other posts, I see where/how to check ABS codes. So why would the yellow ABS light come on when I put on parking brake?
Old Apr 30, 2018 | 10:42 PM
rla2005's Avatar
rla2005
Good question. Since your truck has RABS II you could see if there is a fault code stored. To the best of my knowledge only the red Brake light should be illuminated with the parking brake engaged.
ReBilld
38
Jul 16, 2015 06:16 PM
fords4me1979
1997 - 2003 F150
18
Oct 28, 2013 05:07 PM
351whitewindsor
Aug 9, 2009 11:21 PM
capecove
May 29, 2007 04:47 PM
sheetf250
Oct 30, 2005 08:32 AM
