Modular V10 (6.8l)
Help determine gear ratio
Old Apr 29, 2018 | 11:57 PM
Bleedblue01's Avatar
Bleedblue01
Hey everyone, I am hoping someone can help me figure out what gearing my truck has. I have an 01 f250 V10/auto. I have 35" tires. My RPM's at 70 (GPS not speedometer) are about 2250 or so. I am pretty sure the gearing is not stock. Anyone with a similar setup have any idea? Thanks!
Old Apr 30, 2018 | 07:49 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Using a calculator:
2250 / .7 / 4.88 * (35 * 3.1415946) * 60 / 12 / 5280 = 68.58MPH
2220 RPM / OD ratio / gear * (tire diameter * PI) * (minutes per hour) / (12 inches to convert to feet) / (feet in a mile to convert to MPH)
Old May 1, 2018 | 12:15 AM
Bleedblue01
Originally Posted by Krewat
Using a calculator:
😮😮 well done sir! Thanks for the help! I will double check my speed and rpms to confirm but this helps a lot!
Old May 1, 2018 | 09:46 AM
krewat's Avatar
krewat
Happy to help
Old May 5, 2018 | 05:30 PM
Bleedblue01
Something else I am trying to figure out- my tach rpm in the truck reads higher than my sct x4 tuner by 80-100 rpms.. which is more accurate?
Old May 5, 2018 | 07:50 PM
krewat's Avatar
krewat
The tuner would be more accurate, but may not update as fast as the gauge.
Old May 9, 2018 | 03:32 PM
Bleedblue01
One more question- I calculated the rpms at 70 with the tuner at 2170 rpms. I hand measured the tires and they are actually 33.5" talll.. thanks!
Old May 9, 2018 | 04:51 PM
krewat's Avatar
krewat
Measure them side-to-side not top-to-bottom - the bottom of the tire does compress a bit unless they're aired up to the max (and even then).
Otherwise, it makes more sense that you'd have 4.55's or even 4.30's.
ekm71f100
Feb 17, 2011 08:24 PM
therigwelder
Nov 23, 2010 11:03 PM
HD74
Sep 21, 2009 09:26 PM
51dueller
Feb 26, 2004 11:54 PM
RichieGDTYMS
Feb 15, 2004 12:45 PM
