All that the KAM for the transmission can change is how hard or soft the shifts are. It can't change when the shifts happen, so I can't see how that could affect the MPG.
Like I said, shot in the dark, but easy enough to at least try it out.
SIde note, I thought the adaptive transmissions on the newer trucks adjusted more shift parameters than just shift firmness. I know you, Mark, are definitely the expert on these things and would love to learn what really is adaptive about it.
I have personally noticed the shifting strategy is way more aggressive when I reset my KAM at the beginning of every month (have a tuner so it is super easy to do) as I am a pretty easy driver and hate that it learns my easy style when I don't want to be easy on it or need to move around traffic. It could just be my imagination but it definitely seems to shift later in the RPM band right after the KAM reset.
It's possible that changes to the schedule was added to the adaptive after I left. We tried to make that work while I was at Ford and it was a bust. But maybe they learned something later.
I bet it goes up 2mpg now that we are back on summer bended fuel
While the seasonal fuels might affect those of us in the north, the OP mentions he lives in Virginia. Virginia doesn't use winter/summer gasoline as the northern states do. And if he hasn't not changed where he's filling up then the quality of fuel is likely not the issue.
I live in SE Virginia and I can tell you all that my mileage does in fact change from winter to spring about two MPG's.
Yes, when I reset the trip computer it resets the MPG and I checked the fluid today after a trip of running errands. The display said the transmission temp was 185 degrees, the fluid is bright red and was in the “B” hash marks. I am not sure what this means, the truck was on a level spot when I pulled the dipstick.
On a side note, it was a real pain in the a** to get to! I miss the old trucks that you sat in the engine bay and worked on it and could reach everything, like my 84 with a 302! But I also know that my 84 wouldn’t pull my camper either!
From what I recall the B-range is the higher level? When I did mine I couldn't find anything to explain the two levels so I set mine in the upper range. Can't remember if that was B or A. Haven't noticed any mileage change since that fluid change.
Idea: Take some fluid out, maybe get it to the bottom of the B range and see if your MPG changes. Just use a hand pump & tube down the dipstick hole. Super easy. I used this method to "pre-drain" my tranny before dropping the pan. I was able to remove about 4qts and made it a lot less messy.
Update!!!! I got my MPG back!! No idea how but it is back to normal now. I spent the weekend in Baltimore MD, bc Uncle Sam said to, I left the truck here for the wife to drive and when I got home and drove it on Monday, I notice that the MPG on the computer had improved. I have driven it every day since, maybe a little more than I should, to check the mileage and it is definitely back to normal. I did absolutely nothing to the truck, other than check the trans fluid, so this baffles me.
Thanks for all the help and suggestions, if there is something that anyone finds out please pass it along, I am open to all the knowledge I can get!
I lived in northern Virginia for 20 years so I know that Virginia is a state that does not alternate between winter and summer fuel blends. While your fuel economy may change due to seasonal temperature differences and other factors that are beyond our control, it is not because of different blends of fuel.
I lived in the Stafford/Fredericksburg area and had to fight the traffic of the Washington sprawl for the last 15 years I lived there so my fuel economy always sucked! (That and the exorbitant cost of living is why I moved out of that area in 2007.)
Good deal! My thought in all of this was simply, "maybe you just need to run it one the highway for a while to slosh new stuff in & around." At the time it seemed silly but it's often what needs to be done, particularly with motorcycle cooling systems.
