"Fake" websites stealing FTE data?
I do a lot of internet forum and website searches for repair and maintenance subjects. I've noticed there are some that are obviously run through some sort of translater and spit back out, and aren't "real" websites. For what purpose I'm not sure. Nothing good, probably. They capture forum posts. Here's one from user "SeaCarr", it is in fact an FTE thread from the Y Block section. WTF??
Here's an example of the sentence structure on another, different "fake" website. Nobody talks this way in real life. Notice the use of "many" where the original post or article would obviously have used "most" and other strange or awkward phrases. Definitely has that "Bite the wax tadpole" odor.
"To keep up accurate valve operation at ordinary engine speeds, all the valve springs have to exert a certain level of spring strain. In many stock engines, the stress exerted with the valve springs if the valves are totally closed or seated is all around 70 to 90 pounds. If the valves are pushed many of the way open through the valvetrain, the stress exerted through the springs might go as substantial as 200 pounds or more. In large effectiveness racing engines, incredibly stiff valve springs are typically made use of so the engine can rev greater without the need of the valves floating. Closed spring pressures may well range between 200 to 3oo pounds, and open pressures as substantial as 1000 pounds or greater!"
Received 3,271 Likes
on
This happened some years back and users noticed then, too. That site got shut down after FoMoCo Corporate got a hold of it, copyright violations.
You could submit the site to Ford Corporate and they should be able to shut it down, but IB won't be able to do anything because it's hosted offshore (in Hong Kong).
Online:www.fordbrandlicensing.com
Address:Ford Motor Company,Global Brand Licensing Office,
16800 Executive Plaza Drive, Suite N203,
Dearborn, MI 48126
Dearborn, MI 48126
Here is the whois info on ford-ford.com:
https://www.godaddy.com/whois/result...isc=gofd1001aj
Boss300
03-28-2005 05:42 PM
