Sponsored by: Real Truck
Noise from rear cab/bed area?
Old Apr 27, 2018 | 06:42 AM
Swamp_Yankee's Avatar
Swamp_Yankee
Whenever I hit a bump in my 2012 F250 Supercab I hear a noise coming from either the rear of the cab and/or the bed area like something is loose and banging and squeaking as if a body panel isn't fully secured. However, I've poked around quite a bit back there and haven't found anything that seems obviously loose. Could it be something on the underside like a skid plate or heat shield? The truck did come with an aftermarket back rack, but that seems pretty secure as well.
Old Apr 27, 2018 | 07:46 AM
DogRidesInBack's Avatar
DogRidesInBack
Spare tire?
Old Apr 27, 2018 | 08:36 AM
FractureCritical's Avatar
FractureCritical
are your rails attaching the truck bed to the frame rotted out?
they come pre-rusted from the factory, so...
Old Apr 27, 2018 | 08:56 AM
Swamp_Yankee
I'll check this but I rolled around underneath the truck quite a bit prior to purchasing it and it was remarkably clean. It's an XL work package that was owned by a utility company but it doesn't seem to have ever plowed. It did see salt as the company was based in Massachusetts.
Old Apr 27, 2018 | 12:03 PM
seville009's Avatar
seville009
Shocks may be loose. Happened to me - top bolt in the rear driver’s side shock fell out. Took me about six months to figure out where the thumping was coming from
Old Apr 27, 2018 | 12:27 PM
Batman7777's Avatar
Batman7777
It could be a thousand things.. Spare tire was a good one.. Bed bolts, U-Bolts, Exhaust, etc etc
Get it on a lift and check it out..
Old Apr 27, 2018 | 12:43 PM
jav_eee's Avatar
jav_eee
Check between the bed and cab for foreign objects. I had a piece of wood fall in between that was causing some rattles...
Old Apr 27, 2018 | 03:50 PM
DogRidesInBack
A rubber mallet banging around under the truck might cause the noise.
No, you likely don't have one banging around under there at the moment, but using one is a good way to make things vibrate without breaking them. As I said, it might cause the noise.
Old Apr 27, 2018 | 06:05 PM
Tideman's Avatar
Tideman
Your rear (cab) body mount bushings are gone.
Old Apr 27, 2018 | 07:37 PM
Swamp_Yankee
Originally Posted by DogRidesInBack
A rubber mallet banging around under the truck might cause the noise. No, you likely don't have one banging around under there at the moment, but using one is a good way to make things vibrate without breaking them. As I said, it might cause the noise.
This. I stood in the bed of the truck today and gave the back rack a good whack with my fists and was able to replicate the noise. The rack is mounted pretty securely, but it vibrates just enough on bumpy roads. I'd like to find a way to quiet it as it is kind of annoying-maybe some rubber washers for the mounting bolts?
Old Apr 28, 2018 | 03:18 AM
seville009's Avatar
seville009
If the backrack is easy to remove, maybe do that and drive around a bit to be absolutely sure that was the cause.
Traveling
Jun 4, 2018 09:38 PM
FLFordOwner
Jan 15, 2016 09:03 AM
dfishrmn88
2004 - 2008 F150
Oct 28, 2010 07:45 PM
mrlaw13
Jun 17, 2005 06:47 PM
