Sponsored by: Auxito
HELP
Old Apr 25, 2018 | 06:41 PM
Wheeler Garage's Avatar
Wheeler Garage
HELP
Hello, I have a 2000 F-250 with the v-10. When the battery is hooked up, the starter will engage by itself. With the key in the ignition or not. When it does that, I turned the key to ON and it idled fine then tried to re-engage the starter. I turned the truck off, but it was still trying to engage the starter. I tried replacing the solenoid and battery. Still doing this. WTF?! I was a ford tech and can’t figure this bull out.
Old Apr 26, 2018 | 10:28 AM
Bluegrass 7's Avatar
Bluegrass 7
The small leads on the start relay are on the wrong terminals.
The way it is now, you have battery on the start relay winding full time.
That's the job of the ignition switch through the transmission selector in Park and Neutral when you crank the engine.
Good luck.
Gabrial
2004 - 2008 F150
Jan 11, 2019 05:45 PM
RobW248
Oct 2, 2014 06:53 AM
Raider50
Jul 7, 2014 08:42 AM
wilsonriverfisher
Jun 14, 2007 06:08 AM
Eu07
Bronco II
Oct 15, 2003 11:50 AM
