Finished 4.9 to 5.0 swap no oil pressure or coolant temp on dash
![](https://cimg3.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1504/c55d7311_7c10_4e56_b74a_787e74a47296_bb95f7d12543d3d2e37292151ebd411c615f243d.jpeg)
89 f150
Just swapped in a 302 with MAF conversion.
HO cam and mustang A9L ecu
Running through cam break in right. Now.
My aftermarket gauges show I have oil pressure and temperature is good. But my dash doesn't show oil pressure or water temp. Both sensors are installed and hooked up
Is there some changes in wiring I need to do to make the sensors work??
I am starting to get parts together to do this same swap. I have a few questions:
1. Did you use a kit or did you work out the wiring yourself?
2. Where did you find the EEC connectors to add the new wires (for injectors, MAF sensor, etc) to the EEC?
3. What MAF meter did you use?
4. What size injectors did you use?
5. I noticed that the wiring diagram for our trucks only show one wire for VSS and the A9L wiring diagram show two (one for VSS+ and one for VSS-). How did you handle that?
Thanks in advance,
Michael
Thanks in advance,
Michael
-Bought a harness from runne-rite.com
-On the harness
-Used a mustang g A9L ecu as I have a manual transmission. And the MAF Meter to go with it
-Stock 19lb injectors from my 5.0
-Guessing that's built into the harness like how the harness splits the single O2 sensor reading to satisfy the ecu looking for 2.
I also switched to roller lifters and a ho firing order cam.
Received 1,031 Likes
on
What exhaust is on it? I had the same cam in my '90 and it ripped at higher rpms but the truck had longtubes and a 3" single exhaust.
There are a bunch of things on different pins with the Mustang PCM but the conversion harness should take care of all of that including feeding the single O2 to both inputs.
![](https://cimg5.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1504/ae827eb9_ca0a_4239_887b_329e1f111c11_1013bed1e6ddacc250920a861e41830ad1979aa7.jpeg)
Well 14 out of the 31 wires match lol
Some colors aren't in the other harnesses like the 5.0 has 3 black/yellow the 4.9 has one
Only 2 wires I couldnt figure out in the 4.9 are.
In connector C110
-there is a violet ish colored wire
In connector C113
- black/orange dots
Will need to find the 1990 wiring to figure out those ones. Happen to have that somewhere?
![](https://cimg8.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/1120x2000/ce469070_c08e_4d39_8e0a_15edcf5a894d_9026a4a71712994cf99057f002a52b07e7437ec6.jpeg)
So turns out that a bunch of wire colors changed.
All but 4 of them paired up correctly wheb plugged in.
The IDM feed back to ecu and high coolant temp switch. Were backwards.
No idea what the IDM really does lol
And the oil pressure switch was backwards with the R/Lb #32 wire in the picture which I have no idea what it does
on
Sounds like you have done a bang up job figuring this out so far. Those two sensors are single wire that use the engine as a ground, the easiest thing to do would be to probe the harness from the senders to the bulkhead connectors to find the correct wire and then match that up with the other side from there to the PCM.
I'm just not sure from there. Is that something that runs through the ecu?
The coolant temp might be an ecu thong tho?
on
No and I have to edit my previous reply, the dash gauges have nothing to do with the EFI system those senders connect directly to the dash so the MAF conversion isn't the problem the differences between the 4.9 truck and 5.0 engine harnesses are to blame. When I did the MAF conversion on my 5.0 truck the dash gauges all worked just fine.
