Non stop horn
Old Apr 24, 2018 | 02:54 PM
midsouth's Avatar
midsouth
Non stop horn
Happy Monday. My 1983 f150 4x4 with cruise control has a horn that blows constantly. Do I need to replace the horn relay? If so where is it? Or do I need to replace the horn switch? If so where is it located.
Old Apr 24, 2018 | 03:51 PM
James Wagoner's Avatar
James Wagoner
Keep it that way and just wave to everyone that stares
Old Apr 24, 2018 | 03:59 PM
Sparky83's Avatar
Sparky83
if i remember right that was about the same time they had the cruise buttons incorporated in the face of the steering wheel correct?? if so replace the multi-function switch under the wheel.. its probably on its way out causing the internal short. that or when it was last removed something didnt get connected properly.
Old Apr 24, 2018 | 04:37 PM
midsouth's Avatar
midsouth
Is the multi function switch located in the steering column or elsewhere?
Old Apr 24, 2018 | 04:39 PM
midsouth's Avatar
midsouth
And you're correct.. The cruise control is integrated into the steering wheel.
Old Apr 24, 2018 | 05:45 PM
Sparky83's Avatar
Sparky83
its in the column on top. Its what the turnsignal arm is connected to.
Old Apr 24, 2018 | 06:43 PM
Franklin2's Avatar
Franklin2
We didn't have multi-function switches in these trucks. It was just a turnsignal switch. I don't think it has much to do with the horn. You are just going to have to dive in, take the steering wheel pad off, and see what is causing the problem.
Old Apr 24, 2018 | 10:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1978/86: No Speed Control, NO horn relay!
D6TZ-13853-A (replaced D3TZ-13853-A) .. Horn Relay-Marked: D3TB-13853-A or D6TB-13853-A (Motorcraft HB-112) / Obsolete
1973/77 F100/350 with/without Speed Control // 1975/77 Econoline with/without Speed Control // 1978/86 F100/350, Bronco & Econoline with Speed Control only.
Horn relay located adjacent to the Speed Control Amplifier and/or the fuse box and steering column on the toe board under the dash.
On some 1978/79's, the horn relay plugged into the fuse box. Cannot find a picture for 1980/86 of the little charmer.
mikeceli
Jul 1, 2016 09:48 AM
TheDudeAbides
Aug 2, 2014 01:38 PM
fairfield86f150
Dec 8, 2007 12:01 AM
johnve
Sep 27, 2007 05:44 PM
Rmartens
Sep 5, 2003 01:49 PM
