35s, stockheight??
Old Apr 24, 2018 | 01:52 PM
Liquid10Rider's Avatar
Liquid10Rider
35s, stockheight??
Hey guys I am in the market for new tires and wanted to go for a slightly larger tire. I am looking at 35, 12.5, 20 and was curious if I will have any problems with rubbing while stock height?? And also when I put my 9ft Fisher HD will it possibly rub? I am adding air helpers front and rear soon so that will help keep the truck away from the tires when i put the plow on it.
Thanks,
AJ
Old Apr 24, 2018 | 01:54 PM
Tricon's Avatar
Tricon
Search, this has been asked a million times. 35's fit no problem stock.
Old Apr 24, 2018 | 02:48 PM
pezracer's Avatar
pezracer
You have to be careful of the wheel offset though.
Old Apr 24, 2018 | 02:55 PM
Liquid10Rider
I was going to put them on my stock rims. will that be effected?
Old Apr 24, 2018 | 04:56 PM
Tricon's Avatar
Tricon
Nope, 35's work fine on stock rims.
Old Apr 24, 2018 | 06:11 PM
dustin cri's Avatar
dustin cri
no issues im running 35's on stock 18's
Old Apr 24, 2018 | 08:41 PM
Sonny Crockett's Avatar
Sonny Crockett
Stocks are 8 inch. 8.5 inch is min. recommended for 35's. I got 295/65/20 Nitto Ridge Grapplers. The 295 is in fact a bit taller than the 35. It's 11.77" wide so a touch narrower than a 35/12.5.
Old May 1, 2018 | 10:31 AM
Liquid10Rider
I will be running these on stock 20s
Old May 1, 2018 | 10:46 AM
AMXDREAMER's Avatar
AMXDREAMER
I run 295/65/20 Toyo Open Country A/T's on my 17 Platinum on the stock rims. A hair taller and a hair narrower than the 35 BUT they have a higher weight rating for towing.
Stantheman83
Nov 25, 2017 08:25 PM
badutahboy
Oct 25, 2015 12:06 PM
SneakyF350
6.7L Power Stroke Diesel
May 21, 2011 11:29 AM
1957F100
Oct 30, 2007 11:54 PM
superdarren
2004 - 2008 F150
22
Jan 21, 2005 08:07 PM
