Inner door handles
Old Apr 23, 2018 | 04:53 PM
Okiedokie's Avatar
Okiedokie
Inner door handles
Can I use 56 inside door handles on my 53 shafts?
Old Apr 24, 2018 | 12:31 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Yes, the 53-56 shafts are the same.
Old Apr 24, 2018 | 03:19 PM
sjahnke's Avatar
sjahnke
I believe the 53-55 shafts are all the same but the 56 shaft is different as the 56 handles are held on with a set screw and the 53-55 handles use a spring clip set up.
Old Apr 24, 2018 | 07:44 PM
bjmayberry2
Mid Fifty only sells 1 for 53-56.
Old Apr 24, 2018 | 07:47 PM
Okiedokie's Avatar
Okiedokie
I was pretty sure the shafts were the same since the suppliers don't list two different remotes. I assumed the set screw would do a better job although I have been told that they don't. Had my handles off and the clips always frustrate me.
Old Apr 24, 2018 | 08:49 PM
bjmayberry2
Just a FYI most car companies used clips on their door’s inside cranks for a very long time.
Old Apr 25, 2018 | 05:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1953/55: 357550-S .. Inside Door & Window Handle Retaining Clip.
1956: 371877-S8 .. Inside Door & Window Handle Retaining Screw - Fillister Head #8 -32 x 15/32" long.
Old Apr 25, 2018 | 06:45 PM
dadgonebroke's Avatar
dadgonebroke
Not sure of the quality of the set screws but I usually have a handle fall off on my '56 at least once a week.
Old Apr 26, 2018 | 04:00 AM
Justboy's Avatar
Justboy
I would rather do without handles than put those retaining clip bstrds back on!
Old Apr 26, 2018 | 06:13 AM
abe's Avatar
abe
They are not that bad. And they hold the handle on quite well.
Old Apr 26, 2018 | 06:48 AM
Greg Rogers's Avatar
Greg Rogers
My truck came with a bunch of extra cranks and handles which I believe to be 55's. I also parted out a 56 wrecker. I also got those parts and regulators of a 54 grain truck in a local bone yard. The shafts from the 54-55 and 56 appear to be the same- not positive but appear to be. The parts off the 56 wrecker did have the set screws, One broke off in the handle. Anyway while trying to get a decent set to use on my truck I tried the combinations. It appears the 55-54 parts will fit on the 56 shafts and hold with the clips, but you can't use the chrome/black spacers. It also appears the 56 parts will fit on the 55-54 shafts. The reason I say "appears" is because some of this stuff is worn out and won't fit tight. Also I have some weird "China" window cranks I bought real cheap at a going out of business sale years ago that use clips. I assumed those were for a GM car but they also worked on the 56 shafts. Clear as mud, right??
Old Apr 26, 2018 | 07:32 AM
Justboy's Avatar
Justboy
I have a new set of 56 handles and an old set of 55 shafts, I am pretty sure they will work but not got around to trying them yet. I'll try and make a point of doing it before the weekend and get back to you but can't promise.
Old Apr 26, 2018 | 07:34 AM
Justboy's Avatar
Justboy
I fully support your second statement.
Old Dec 20, 2023 | 03:26 PM
Ferd3's Avatar
Ferd3
FYI
I'm replacing my inside window crank handles (ordered them from Obsolete Ford parts in Oklahoma City) on my 1953 F100 and the crank has a place for the set screw, but no set screw came with the cranks, clips were included.
Found that to be interesting.
Ferd Koehn
San Angelo, Texas
1953 F100 inherited from my granddad.
Old Dec 20, 2023 | 03:46 PM
abe's Avatar
abe
Fred, I see you are relatively new to FTE. Welcome to FTE the best Ford truck forum on the World wide Web!
Starts new thread introduce yourself and tell us about your family heirloom 53. Include pictures of your 53.
