'95 7.3 starting problem
Old Apr 27, 2018 | 01:25 PM
knottyrope's Avatar
knottyrope
IPR 18 at idle isn't great, might be blown injector o rings
Old Apr 27, 2018 | 03:15 PM
97-psd's Avatar
97-psd
Open the fuel bowl and see what f it has fuel in it. Still need a fuel pressure. Use the process knottyrope suggested
Old Apr 27, 2018 | 04:23 PM
Jvradenburg's Avatar
Jvradenburg
4wd Low
Well if I can get it to run like previously stated wouldn't that mean it's getting fuel?...
Old Apr 27, 2018 | 04:25 PM
Jvradenburg
4wd Low
Originally Posted by David7.3
Crank sensor codes can set due too excessive long crank times. Make sure your batteries are charged up!! Need to see the 3 APP voltages. A week battery or slow cranking can screw up the IDM and PCM making ya chase your tail!!!
Did you see where I said they came up after I unplugged the foot pedal? Lol
Old Apr 28, 2018 | 08:34 AM
fordman67's Avatar
fordman67
Nope. You need to manually check fuel pressure at the filter housing.
The hpop pressures are good,over on. 18%at 700 is fine.
Need to determine if fuel pressure is ok. Batts must maintain 10.5 v while cranking . I have had them sound good but be dropping just below at 10.
test don't assume
Old May 1, 2018 | 01:55 AM
Bluediesel250's Avatar
Bluediesel250
Have you double checked your engine oil level? If it's a bit low it can play real funny games with these engines because the injectors need oil pressure to fire
disturbinglee
Sep 4, 2019 08:39 AM
PatrickMM
Dec 13, 2017 06:31 AM
Engalwood
Dec 8, 2014 09:35 AM
Smokey_7.3
16
Aug 23, 2014 12:58 AM
jcarr922
27
Jun 19, 2006 10:30 PM
