Burned UVCH Connectors and Questions
Long sordid story but my truck is out of service for the first time. Had it for several years now without a problem. I discovered at least one burned UVCH connection and I went ahead and ordered Super Duty gaskets, pigtails and UVCH's from Riffraff. Of course I'm thinking that since I'm going to be in there I needed to add glow plugs to the order since they are 220,000 mile originals.
To take the "since I'm going to be in there" syndrome one step further I think I'm going to order rebuilt injectors since they are original also.
To keep going with the "since I'm in there" should I replace the injector cups too? No sign of any fuel in the coolant. I've never replaced injector cups before and there's always the chance I'll screw up and end up with a problem where none existed. How do the cups fail? Is it corrosion or cracking or just leaks past old deteriorated sealant?
Appreciate any opinions or experience on replacing injector cups that aren't leaking (yet?).
Thanks.
Thanks.
I'm from the "if it's not broken don't fix" time. I'd say since you are not having any problems with the cups, leave them alone. There are hundreds of trucks with more miles on them still running the original cups. Good call on the glow plugs, as the melting probably came from a failing plug drawing more amps.
Thanks to all who replied. Sorry I disappeared, been busy with numerous other follies and I was feeling like one of those guys who pop up and ask questions, then never return or report back on how things turned out. My original plan was to order rebuilt injectors this morning so I'd have them ASAP. Interesting how I went decades without this truck and now that I've had it for a few years I don't even want to go a week without it. I may just do the harnesses and glow plugs and save the injectors for later. Probably pass on the injector sleeves but I wish someone made stainless steel ones that would fit. I'd be more inclined to change them if I could go to stainless. Adam, thanks for the comment about being able to use ELC coolant with the right cup sealant. Something more to think about.
since you are doing UVCH and GPs, get a armature kit and maybe injector o ring kit
Also do a intake leak test, good time to seal plenums if you need to.
or go nuts and do new fuel pump, bowl rebuild, new diesel rubber lines, IPR o rings, EBP tube clean and anything else you wish to do
scottm1
04-14-2017 02:44 PM
Finally Powerstrokin
01-03-2012 06:43 AM
