Clutch equalizer alignment
Old Apr 23, 2018 | 08:49 AM
JKessler00's Avatar
JKessler00
I installed my engine Saturday morning after a rebuild and as I am putting the clutch linkage back together, I notice the z-bar completely out of kilter. The motor mated with the trans and sat right into place without much issue - and it appears level. I can't move the inner bracket up. What in the world did I do?
Old Apr 23, 2018 | 09:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year, series and engine size?
Old Apr 23, 2018 | 09:24 AM
JKessler00's Avatar
JKessler00
'77 F-250 4WD, NP manual trans, was a 351M but is now converted to 400
Old Apr 23, 2018 | 09:32 AM
NumberDummy
Old Apr 24, 2018 | 07:28 AM
JKessler00's Avatar
JKessler00
I wish I would have taken a "before" pic. I'm sure it wasn't like that.
Old Apr 24, 2018 | 06:24 PM
JKessler00's Avatar
JKessler00
I've gone over it and I cannot see anything wrong. Is there any chance I have the motor mounts backwards? That's the only thing I can come up with.
Old Apr 24, 2018 | 09:23 PM
HIO Silver's Avatar
HIO Silver
Your engine is not sitting level... the perch holes may need to be elongated
Alternatively, check if the engine-side bracket is assembled/oriented correctly.
Old May 3, 2018 | 07:40 PM
JKessler00's Avatar
JKessler00
The engine sat perfectly level. Everything checked out. I didn't do a 460 swap but I found the following thread where several others had the same problem: https://www.ford-trucks.com/forums/1...vel-460-a.html
I pressed out the stud, drilled a new hole 1/2" higher in the bracket, and welded it in. All is well now.
The other problem I still have is that the clutch pedal does not return after pressing it down. The clutch is working but I have to help the pedal up. I've adjusted the pencil both forward and back and it doesn't seem to change.
Old May 3, 2018 | 08:49 PM
meangreen92's Avatar
meangreen92
Do you have the return spring on there?
Old May 3, 2018 | 09:16 PM
JKessler00's Avatar
JKessler00
Yes, there's good tension
Old May 3, 2018 | 10:17 PM
meangreen92
It's probably the Z-bar binding. Try disengaging the threaded shaft from the clutch fork, and see if the pedal feels like there's too much resistance.
With the pedal moving only the Z-bar, there should be barely any resistance - other than if the return spring is still connected.
Old May 7, 2018 | 06:06 PM
JKessler00's Avatar
JKessler00
Negative. The z-bar moves freely when disconnected from the adjusting rod. I got the new motor running today and thought I'd take it for a spin. I couldn't even get the trans out of neutral. It's worse than I thought. The throwout bearing is new and came with the clutch. I don't see how it could have gone on wrong so my hope is that the adjusting rod is just too short for some reason. It looks as if it has been modified in the past. I get more than half way down on the pedal before I feel the slightest of resistance from the pressure plate.
Old May 7, 2018 | 08:10 PM
Filthy Beast's Avatar
Filthy Beast
Does sound like the adjusting rod....how's the angle between the throwout arm and Z bar connection. Do you have the "swivel" still working on the Z bar?
Old May 8, 2018 | 11:04 AM
JKessler00's Avatar
JKessler00
I'll have to have the wife press the pedal for me tonight so I can watch what is happening. I'm not sure about the angle of the arm and zbar. I do recall the new throw out bearing being nearly 1/4" less in thickness than the old one but it came with the clutch so I assumed I should put it on. Maybe that's where the adjusting rod is coming in; I can't accommodate for the increased range needed.
Old May 14, 2018 | 08:00 AM
JKessler00's Avatar
JKessler00
It was definitely the adjusting rod. I now have a clutch and the pedal springs back exactly as it should. Whew!
lvin4jc
22
Nov 20, 2019 08:49 AM
hail destroyer
Jul 14, 2019 11:41 PM
hail destroyer
Jun 24, 2019 06:24 AM
wtroger
Mar 22, 2019 02:06 PM
Fuzzydog
Jul 31, 2012 02:47 PM
