Automatic Trans Steering Column
Old Apr 19, 2018 | 07:39 PM
johnmel59's Avatar
johnmel59
Good day FTE,
can I convert my existing 3 speed manual transmission steering column to an Automatic transmission column? If not, is there a replacement column available from a supplier or compatible steering column from other models/years? I currently have a 1965 240 with the 3 speed manual transmission. Thanks in advance!
Old Apr 19, 2018 | 08:34 PM
TA455HO's Avatar
TA455HO
Lead Gopher
What year is your truck? I believe the outer tube itself is different because there is a spot for the neutral safety switch and it's activating tang on the inner shift tube, which is different.
Instead of the two arms and various shims at the lower end there is this one arm and a heavy duty spring for the automatic.
Only one of the levers NOS that I could see at a quick glance. Used could be fine, too.
C5TZ-7302-B - Transmission Gear Shift Selector Lever Assembly
The spring sits just above this lever inside of the tube and outside of the shaft. Several available NOS.
C0DF-7379-A - Transmission Gear Shift Selector Tube Spring - 2" free length - 6 coils
Then the upper steering column bowl is different. The tube flange between the bowl and the tube is different. You'd probably have to source another automatic column to get some of the parts since they are hens teeth.
Newer year Ford trucks can be a source.
Old Apr 20, 2018 | 06:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
A/T vs 3 M/T: Shift tube (7212) is different as is the shift lever (7210) and related parts, shift collar (7228), mast jacket (3514 - steering column shroud), upper flange (3511), selector lever (7302), rod from column to trans (not shown).
A/T's have a kickdown rod (not shown), NSS switch (7A247) & selector lever (7B097).
Pic: A/T at upper left & lower right. Basic part numbers shown in pic.
Old Apr 23, 2018 | 11:37 AM
Old Coyote's Avatar
Old Coyote
What kind of transmission are you planning to swap in there? Have you considered leaving the 3-speed column in there and installing a floor shifter for the automatic? Lokar makes some nice kits.
Uni Moe
Aug 14, 2016 10:21 PM
RJRPC
May 3, 2013 11:59 PM
Layne
Nov 17, 2011 08:57 PM
SNEWTON
Oct 8, 2008 04:26 PM
gusso
Mar 29, 2007 01:31 PM
