Sponsored by: Real Truck
Help- Part Needed
Old Apr 19, 2018 | 06:14 PM
Kountryguy's Avatar
Kountryguy
Help- Part Needed
I have a 2011 F-350 6.7 Powerstroke. Last week I smelled fuel and found fuel leaking from the top of the fuel pressure sensor part# BC3Z-9S599-C. I went to a dealer who, at first, told me the truck was unfixable because the part was on longer made. After several hours trying to locate one, they took one off a motor that was going to be replaced so we could get back on the road. Since then, I have been trying to find one, with no success. I would like to get a new one for a spare. It has been very frustrating and to think that these trucks are rendered useless just because Ford decided it does not need to stock this part. Any suggestions?
Old Apr 19, 2018 | 06:32 PM
seville009's Avatar
seville009
If you google the part number without the dashes, there are Ford dealers that pop up with the part in stock.
Old Apr 19, 2018 | 08:31 PM
Kountryguy's Avatar
Kountryguy
Many of the places that list the part, when I call, they do not have it. Will keep trying.
Old Apr 19, 2018 | 08:40 PM
shawn.snow's Avatar
shawn.snow
Looks like auto nation Ford White Bear lake may have it. They are my go to for dealer only parts and have been great to work with.
https://parts.autonationfordwhitebea...ure-bc3z9s599c
Old Apr 19, 2018 | 09:12 PM
Kountryguy's Avatar
Kountryguy
Thanks, but I checked with them this afternoon and nothing available, and no idea when or if it will be.
Old Apr 19, 2018 | 09:23 PM
shawn.snow's Avatar
shawn.snow
Not good. If the part is discontinued I wonder what part is supposed to replace it. I wonder if M-chan68 has any insight
Old Apr 19, 2018 | 09:33 PM
Fordbronco1995's Avatar
Fordbronco1995
Pm sent with a place that supposedly has it. Let me know if it worked out for ya
Old Apr 19, 2018 | 09:34 PM
Kountryguy's Avatar
Kountryguy
Spoke to a customer service rep at Ford today and she had no suggestions and offered no help. I have been told by two Ford dealers that the truck is not repairable. Sure does not make me want to purchase another Ford.
Old Apr 19, 2018 | 09:36 PM
Fordbronco1995
Kountry check your pm, not sure if you came across that place yet but worth a try, says they have 1 left
Old Apr 19, 2018 | 09:38 PM
shawn.snow's Avatar
shawn.snow
I understand how you feel Kountryguy. Its a part that may eventually fail and when it does they have 0 replacements I just cant wrap my mind around that as I am assuming they are still using it on the 6.7's and there have been atleast a few reports of this failing on other members. It makes me a bit nervous as well I will keep an eye out and continue to look for some as I will be ordered one as well to keep on hand just in case.
Old Apr 20, 2018 | 10:40 AM
Kountryguy's Avatar
Kountryguy
I called 3 more dealers this AM and still no luck. I would like to find someone in Ford management that acted like they cared enough to help solve this problem. If anyone has any other ideas, I would be very grateful.
Old Apr 20, 2018 | 10:46 AM
Fordbronco1995
Did you have any luck with the dealer i pm’d you about?
Old Apr 20, 2018 | 10:53 AM
Kountryguy's Avatar
Kountryguy
I called them this AM, but they did not have one. He was going to place an order and try to locate one. He said he would call me this afternoon with the results. I will see what happens.
Old Apr 20, 2018 | 11:03 AM
99f350sd's Avatar
99f350sd
Call Bill hewitt down in Georgia. Powerstroke help.com
Old Apr 20, 2018 | 11:19 AM
Kountryguy's Avatar
Kountryguy
Tried calling, no luck with getting an answer. I emailed him and I will see if I get an answer. Thanks for the idea.
