351 Won’t crank
Old Apr 18, 2018 | 08:48 PM
2fifty's Avatar
2fifty
351 Won’t crank
my 1991 f350 with the 351w 5 speed wont even crank anymore. It always started fine but always cranked slowly and then this morning it wouldn’t even crank. Just replaced plugs wires battery and distributor like a month ago. Any help or suggestions help. Thanks
Old Apr 18, 2018 | 11:38 PM
1TonBasecamp's Avatar
1TonBasecamp
Well none of that stuff other than the battery can keep a starter from cranking. And new stuff does go bad these days more often than ever before. So you could have a bad new battery.
But many other things can cause a starter to not spin as well. You said it was cranking slowly before. Was that due to an old tired batter and the cold weather? Is that why a new battery was installed?
Do you get any clicking or anything else?
What does your voltage at the battery read when you turn the key? Any change from normal?
Since you have a manual transmission. does a '91 still use a Neutral Safety Switch like an automatic does? Or is the '91 using a bypass? Or perhaps a clutch interlock switch?
Reason I ask is that you can have an NSS go bad and keep the engine from cranking. Clutch interlock switch?
In the older trucks, there was a simple jumper wire to take the place of the NSS that would have been present with an auto, and those used to go bad too sometimes.
The fender mounted starter relay can go bad as well. So you can see that you have some testing to do.
1. When you (or a helper to make it easier) turn the key to START, do you get 12v to the Red w/blue wire at the starter relay?
2. When you jump the battery cable to the small "S" post that the Red w/blue wire is connected to, do you get a click at the relay/
The answer to those questions can narrow things down greatly and send us (hopefully) down the right path.
Good luck.
Paul
Old Apr 20, 2018 | 10:52 PM
2fifty's Avatar
2fifty
Thank you for the info! It took about 10 minutes of cleaning connections and checking grounds and it was just the little wire to the starter! The connection was PACKED with mud (don’t know how that happened ) now she starts no problem
Old Apr 21, 2018 | 10:40 AM
1TonBasecamp
Well there ya go. The basics first, then the fiddly stuff.
Glad you got it figured out.
Paul
brocobilliam
1978 - 1996 Big Bronco
Jan 2, 2006 01:47 PM
Livsgrrl30
Electrical Systems/Wiring
28
Jun 9, 2004 08:02 PM
skydiver
Aug 30, 2003 10:05 AM
1980_F250_PA
May 9, 2003 10:33 PM
kevinmurch
Apr 29, 2003 02:05 PM
