1978 - 1996 Big Bronco
No Start
Old Aug 29, 2003 | 05:49 PM
skydiver's Avatar
skydiver
No Start
88 EB 351W. Stopped at store yesterday, came out and all i got was a click at the starter relay. Tried jumper wire between S term and pos term on relay and same 'click'. Wound up using jumper cables from batt directly to starter and it started. Put in new relay and still got same 'click'. One thing to note is i've had to turn key switch a little harder lately before it would start. Any help is great.
Scott
Old Aug 29, 2003 | 07:31 PM
andym's Avatar
andym
No Start
It sounds like you may have either a dead battery, or bad battery cables. They could look OK, but internal corrosion can make them useless. The starter draws a LOT of current, and needs a nice clean path from the battery.
Old Aug 30, 2003 | 10:05 AM
bigric's Avatar
bigric
No Start
I had the same problem with an Explorer a couple of months ago. I cut off the cable ends at the battery and stripped back about 3/4", only to find lots of corrosion. Cleaned it up, put new ends on, and it fired right up.
BluGator2000
Jun 12, 2020 06:56 PM
dvcroket
May 17, 2014 07:49 PM
manger
Oct 9, 2008 08:38 PM
afinepoint
Electrical Systems/Wiring
Apr 25, 2005 09:56 AM
patmorrison
13
Feb 27, 2004 03:20 PM
