Shortbed Replacement
Old Apr 18, 2018 | 09:09 AM
KLONDON's Avatar
KLONDON
I’m looking to replace the entire shortbed on my 1996 Ford F-250 diesel, due to the excessive rust on the lip of the wheel wells. I was told this would be a more effective and efficient way to remedy this, vs. buying replacement panels and having them welded in.
Are the 1987-1996 shortbeds all the same in shape?
One thing different I noticed on the one I found from a 1987 model, is that it only has one fuel door vs. the dual doors I have on my 1996. I’m thinking this could be a very minor adjustment.
Please advise, as I’m thinking the deal I found could be a very good route to go with a replacement for only $150-$200 for the complete bed.
Old Apr 18, 2018 | 09:57 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
The beds on any 1987-1996 are all the same design, they should bolt right up no problem. Obviously make sure you get the correct fuel door arrangement (1 or 2 doors) depending on what you have right now. Even a 1980-1986 would bolt up, however the styling is not the same and it wouldn't match.
Old Apr 18, 2018 | 09:58 AM
rla2005's Avatar
rla2005
Post #2 in this thread: https://www.ford-trucks.com/forums/1...l#post17926503
Old Apr 18, 2018 | 10:09 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Problem with replacing the box is that if you live in a rust prone area and your wheel lips are rusted through, chances are very high that every box you find will have some degree of the same affliction. If your floor remains rust free, I would seriously consider changing the wheelhouses and wheel opening repair panels.
Importing rust free parts from another area can get expensive
On the fuel door, I think patching in a second fuel door is as much work as replacing a rusted wheel lip, so there really is no gain here.
Old Apr 18, 2018 | 01:05 PM
jas88's Avatar
jas88
Sent you a PM.
Old Apr 19, 2018 | 06:34 PM
Diesel_Brad's Avatar
Diesel_Brad
OP is in Texas so I am doubting rust to be an issue
Old Apr 19, 2018 | 07:29 PM
KLONDON's Avatar
KLONDON
Looks like Jas88 may have one for me. I’m trying to get up to him to check it out. I was also thinking of a CM brand flatbed.
Anyone have any advice on going with a flatbed?
Old Apr 19, 2018 | 08:39 PM
daltonjamesadams's Avatar
daltonjamesadams
I have a decent one in Northeast Arkansas, 2 fuel doors, very little rust over 1 wheel.
Brian15501
May 20, 2016 09:34 AM
4x4ford33
Jan 6, 2015 09:35 AM
jvmcc
May 31, 2014 04:04 PM
cjduchon
Paint & Bodywork
May 10, 2004 11:19 AM
MuchToMyDelight
Nov 19, 2003 10:27 PM
