Door Seals
Old Apr 17, 2018 | 02:07 PM
Suffolkman's Avatar
Suffolkman
Door Seals
I have just purchased a 1950 F1. A simple question... should the doors have a rubber seal all the way round each door ?. My truck has nothing on the front edge. The passenger door rattles badly, I am thinking because it has no rubber seal ?. If this is the case, I can probably purchase some here in the UK. What I really need is a short piece of seal of the correct pattern . A big ask I know, but does anybody have a small piece they could possibly post to me ?. Then I could get it matched and do a proper job and reseal both my doors. Apart from the doors, the truck is pretty much rattle free. Any help/advice would be much appreciated.
Suffolkman
Old Apr 18, 2018 | 03:56 AM
Badmoonreizen's Avatar
Badmoonreizen
If you are going to redo both doors, why reinvent the wheel? Buy the proper set from Mid-Fifty, Dennis Carpenter or Steele rubber, and you can be assured they will fit
.https://www.steelerubber.com/door-we...rip-20-0499-72
48 - 52 Parts - Mid Fifty F-100 Parts
Door Seal Kit | Dennis Carpenter Ford Restoration Parts
Regards, Mark.
Old Apr 18, 2018 | 04:55 AM
Suffolkman's Avatar
Suffolkman
Thank you for your reply. I was thinking that the seal would be one length of the same profile rubber right around each door. I can see from the links you attached (many thanks) that is not the case. I will order the 2 door kit from one of the suppliers.
Suffolkman
green53
Sep 11, 2014 12:06 PM
jvmcc
Aug 12, 2013 08:06 PM
F-100CustomCabTBC
28
May 26, 2013 08:44 AM
'nilla60
18
Jan 10, 2007 05:54 PM
