Torn between gear ratios
Old Apr 17, 2018 | 03:35 AM
crucialprospect's Avatar
crucialprospect
Have a 86 1 ton 460 4x4 currently has stock 3.55 gears with 35” tires. I never hauled a loaded trailer with it in that configuration, and since switched to a 35” tire. Engine has been warmed up a bit since then, but still don’t have a granny gear, or the ability to stay in a particular gear on decent incline. I wanted to switch to a 4.10 ratio which is the equivalent to stock set (3.55 with 31”) vs (4.10 with 35”) I find myself shifting from 3rd to 2nd on inclines around 45mph with a loaded trailer, bringing revs up pretty darn high. The cam is all in at 4500 and was told I would be better off with a 3.73 because of highway speeds (70+) unloaded. I hate the fact that I have to downshift a rather powerful engine combo just because of the gear ratio, but now I’m unsure of whether the 4.10 is the best option. I have the front gear set in 4.10 all ready to drop in, so that scores a win in that category, but I’m rebuilding the rear with a Detroit truetrac, so I’ll need the ring and pinion, install kit and carrier. Most of my heavy hauling is 65mph max and maybe faster empty, I know I need a gear swap, but only want to do this once! I don’t sit to gain much with fuel mileage with a 3.73 over a 4.10, but it’s rather important I keep the t-19 in its powerband.
Old Apr 17, 2018 | 03:46 AM
David7.3's Avatar
David7.3
I believe you have thought this thru and would go with the 4:11's especially with your cam. no overdrive and without a granny gear hurts. You have to make the best of what you have, I may even look abit steeper with a 4:56 gear with those big tires. You are correct a 3:73 wont be much different. I would go steeper and let the engine run in it's powerband obviously mileage is not a priority but hauling a trailer you would see a big differance with the 4:56's. Just my 2 cents with experiance in changing ratio's too often. see what other people say!!!
Old Apr 17, 2018 | 02:48 PM
crucialprospect
The only reason I didn’t think 4.56 was because of the carrier break at 4.10 ratio on the front axle. You’re right, I don’t have granny or overdrive with the current setup, may as well choose one or the other!
Old Apr 17, 2018 | 05:09 PM
Franklin2's Avatar
Franklin2
I pull heavy loads with my diesel, and I have 4.10's with 35 inch tires. I do pretty good, espeically considering the horsepower I am working with as my engine doesn't have a turbo. But what makes the difference in my setup is the zf 5 speed. I think you should go ahead with your 4.10's, and then save up for a zf 5 speed swap, it should bolt right in where the t19 is now. Then you would get your highway cruising rpms back and a little fuel mileage also. I gained 3 mpg when I pulled the c6 out and put the zf in place. You could probably expect somewhere around a 2 mpg gain swapping out your t19.
Old Apr 17, 2018 | 06:25 PM
crucialprospect
I thought by hopping up the 460 would cure that problem, but it really didn’t. I’m either bogging 3rd gear around 1200rpms or screaming 2nd gear at 4500rpms on a small incline 35mph loaded. Hopefully the gear swap will cure this! Good call on the zf, I’ve been looking for many years for one in my area, most all are 2wd, and for the 7.3. Maybe someday.
ive decided that it’s not a highway cruiser, so the lower rpm at highway speeds aren’t as important, I’d much rather have the low speed torque.
Old Apr 17, 2018 | 10:08 PM
Nothing Special's Avatar
Nothing Special
Originally Posted by crucialprospect
I thought by hopping up the 460 would cure that problem, but it really didn’t. I’m either bogging 3rd gear around 1200rpms or screaming 2nd gear at 4500rpms on a small incline 35mph loaded. Hopefully the gear swap will cure this! ....
I'm assuming you are calling the T-19 gears L-1-2-3. If so, then 3rd (high) gear with 35" tires and 3.55 gears would give you about 1200 rpm at 35 mph. But dropping one gear will only bring the rpm up to 2000. Heck, dropping to 1st (not L) would only give you 3700. So if you're getting 4500 rpm at 35 mph in 2nd gear, something is SERIOUSLY wrong, like a completely fried clutch (or a tach that is worse than worthless).
Old Apr 17, 2018 | 10:46 PM
James Wagoner's Avatar
James Wagoner
I'm planning an E4OD built up for towing and gear vendors under/over kit. I have 3.55 with stock height tires on my 250HD and might go 3.73 depends on what kind of towing I will be doing.
Been researching like crazy trying to get a double overdrive result with a 6spd TKO but getting to much lash back about it talking with vendors like RS Gear that beef up the TKO 6spd. With Gear Vendors Over/Under, splitting gears to help keep my 460 in the power band and then lockout the final overdrive while towing sounds good. The when cruising I can have the double overdrive to keep the 460 quiet doing 65 - 70 on the highway. Bonus is that I don't have to convert to a manual and will spend less.
Old Apr 18, 2018 | 03:46 AM
crucialprospect
Zf5 or zf6 or even the t-19 with a gear splitter are all very nice options and are high on my WANT list, however, none of those options are in my price range or available right now.
I was only looking to raise the rpm of each gear at the same mph to keep it in the powerband better. I agree, the t-19 is not the best transmission due to wide ratio and no overdrive. Based on my example, instead of having to downshift to 2nd, I will have a higher rpm in third to hold the hills. I will sacrifice top speed at the gain of getting granny gear back (I’m currently using it as a 1st gear and can’t crawl unless the t-case is in low range).
Old Apr 18, 2018 | 04:19 AM
David7.3's Avatar
David7.3
Stick with the 4:10 as that is your only option, like you said low end torque is what you want and that is what that monster under your hood was design too do!!!!
Machman
All Things Towing
Sep 26, 2015 11:17 AM
fordtruckowner
2004 - 2008 F150
29
Feb 8, 2015 01:45 PM
dwardle
19
May 19, 2009 04:27 PM
Customz
Oct 8, 2005 01:35 AM
79 Trailer Special
Feb 20, 2004 07:46 PM
