Wiring Gurus please...
Old Apr 16, 2018 | 03:22 PM
resonateur's Avatar
resonateur
Working on salvaging my '66 main loom and fortunately I have a 65 loom to rob from and splice in the damaged sections. I'm trying to identify every connection and I can't seem to find this one in the wiring diagrams. There's two sections to the main under dash loom, one of which exits the firewall into the engine compartment. Through the firewall there's a green/w/red tracer wire that is cut and goes nowhere in the engine compartment. I'm assuming it was for some accessory that this truck never had. It goes to this double male/female plug under the dash (shown). The female end of both looms I have was not connected to anything. The male end goes to a blue/w/
red tracer wire just over the light switch connector, which is the indicator light circuit. Can I assume, that I can eliminate this wire as it seems to have no purpose? As always, I appreciate the expertise on this forum, which has gotten me this close to completing my project!!
Old Apr 16, 2018 | 09:30 PM
gcooter's Avatar
gcooter
I don't see a green wire with the red tracer in this diagram. I changed alternator types and on the newer alternators the green wire with the red tracer runs from the internal regulator on the alternator to the idiot light or amp gauge in the dash.
Old Apr 17, 2018 | 04:17 AM
Crop Duster's Avatar
Crop Duster
The Green/Red in the oil/alt harness,( C5TA-10A665-C ) was cut off in both of the harness's I took apart. I suspect as you do that it was for something in a much larger truck. I removed it when I re-taped the harness.
I do not see this red tracer wire you speak of but if it the red/yellow tracer under your thumb, it's for the dimmer switch and if it is the one with blue tape on it, that one I believe is for rear lights, which I assumed to be marker lights on a camper. It's useful for other things keep it.
Old Apr 17, 2018 | 04:22 AM
David7.3's Avatar
David7.3
You can use it for , aux. wiring up to running lights or cab lights, it would be a nice addition put since it doesnt dim, I wouldnt use it for gauges or something of that nature.
Old Apr 17, 2018 | 09:50 AM
resonateur's Avatar
resonateur
All:
Thanks for your help!! Yes, I was going to keep the indicator light wire for the purposes such as you suggested. The red tracer is really hard to see as the green wire has become so dark with age. The dimmer switch wiring is intact. As CropDuster suggested, and I assumed, the "wire to nowhere" is going away.
Thanks again....
Old Apr 17, 2018 | 02:59 PM
Fords & Whalers's Avatar
Fords & Whalers
I recently purchased the same wiring harness (C5TA-10A665-C) for the optional oil/alt gauges I installed on my 1965 F100 dash panel, and the green/red wire was also nipped off on the engine side of the rubber firewall grommet . Quick favor, can you send a photo (or description) of the location of the hole for the rubber firewall grommet? I have to drill this in my firewall since I'm adding the gauges and wiring harness myself and want to make sure it's in the correct location.
Old Apr 17, 2018 | 10:35 PM
resonateur's Avatar
resonateur
Fords...here you go. The hole is .85" inside diameter, with the edge rolled in towards the inside of the firewall.
Old Apr 18, 2018 | 12:26 PM
Fords & Whalers
Excellent photo and description, thank you!
Ben Samways
17
Sep 1, 2017 11:07 AM
1930 Dodge
Mar 14, 2016 09:54 AM
alpha/omega
Offroad & 4x4
Jun 6, 2011 08:35 AM
txfour
May 20, 2009 06:56 PM
78blackf150
Nov 22, 2007 03:26 PM
