Offroad & 4x4
wiring help
Old Jun 5, 2011 | 06:30 PM
alpha/omega's Avatar
alpha/omega
wiring help
I need some
Old Jun 5, 2011 | 06:37 PM
alpha/omega
Ok, I guess I can post now. FTE locked up the past two times I tried to start this thread. = pissedmeoff
On the key switch there is a large 8-10ga yellow wire that joins a large 8-10ga black with yellow stripe wire at a fuesable link. The black with yellow stripe wire is supposed to go to the starter solenoid based off the schematic Ive been using BUT this wire has a plug that also joins a smaller 12-14ga yellow with black stripe and red with green stripe wire at its end. When I hacked up my factory harness I labeled the two smaller wires went to the factory amp gauge.
so, could the schematic be wrong and this wire actually go to the alternator or am I missing something?
Schematic Ive been using
Plug in question
Old Jun 5, 2011 | 07:21 PM
fatdan460's Avatar
fatdan460
shyte, i always get confused on stuff like this. ummm........uhhhhh.....ohhhh.......fork!!!!! cut the blue wire!!!!!! cut it now!!!!!
Old Jun 5, 2011 | 07:31 PM
alpha/omega
as usual, youre absolutely no help.
Old Jun 5, 2011 | 07:37 PM
fatdan460's Avatar
fatdan460
what did you expect? the last wiring thread you posted i said something like "hey kris i can't wire anything more than stereos and offroad lights, let me know what info you find about the color coded wires so i can clean up and fix my wiring."
Old Jun 5, 2011 | 08:02 PM
alpha/omega
youre right
anyone else? I dont want to venture out from the safety of the offroad forum to the evil lair of teh 73-79s
Old Jun 5, 2011 | 08:41 PM
thekingofcows's Avatar
thekingofcows
Don't the three smaller wires have something to do with the voltage regulator on the fender? Or maybe the gauge? I don't really remember. The only time I have messed with that part of the harness was to when I did a 3g swap.
Old Jun 5, 2011 | 09:21 PM
alpha/omega
the two smaller wires go to the factory gauge based on my tags before I cut the wires at the cluster.
If you remember what wires you cut/spliced for the 3g alternator that would help some. As of right now the only wire I have unaccounted for is something for the alternator so this big black/yellow must be it.
Old Jun 5, 2011 | 10:27 PM
thekingofcows
Seems like I cut the green wire and spliced into the exciter terminal on the new alternator. There are two places if I remember right where there something like a 6 or 8 gauge black wire. One feeds the battery side of the starter solenoid, and one feeds the fuse block inside.
Old Jun 6, 2011 | 01:00 AM
hav24wheel's Avatar
hav24wheel
I'm with Dan on this, I'm useless. U haven't been under the dash of one o them in years.......
Old Jun 6, 2011 | 08:06 AM
351slug's Avatar
351slug
I hate wiring
This will give you a headache.....
1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
Old Jun 6, 2011 | 08:35 AM
alpha/omega
Yeah, Ive printed all those out. Still not much help for this one wire.
Its not like I need another excuse to drink
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
