Sponsored by: Auxito
2002 f150 fly 2wd brake issue
Old Apr 15, 2018 | 06:28 PM
David Howell's Avatar
David Howell
Ok, 2002 f150 all new calipers, rotors, pads, hoses, master cylinder, abs bypassed, and I still have a very spongy brake, and I have bled gallons though using 2 person method and with a vacuum bleeder, brake pedal drops st8 to the floor, I'm lost
Old Apr 15, 2018 | 06:30 PM
David Howell
Is it possible the upper piston in the front calipers has air trapped?
Old Apr 15, 2018 | 08:55 PM
pdqford's Avatar
pdqford
Do you have the correct caliper on the correct side?
If the caliper is mounted on the wrong side of the truck, the bleeder screw will be at the bottom of the caliper and will never purge any air from the top portion of the caliper.
Old Apr 15, 2018 | 09:00 PM
David Howell
I believe that's a winner, my bleeder are on the bottom
mturner3224
1997 - 2003 F150
Jul 3, 2020 08:44 AM
Papasmithnc
1997 - 2003 F150
Aug 29, 2014 07:35 AM
ren60
1997 - 2003 F150
Jun 19, 2014 05:27 PM
RSCHAP1
Jul 23, 2011 11:52 AM
Dogmaboo
Apr 11, 2004 12:50 PM
