What E4OD pan do I have?
Old Apr 15, 2018 | 10:18 AM
serpa4's Avatar
serpa4
Plug
deepest part
Good day all. I have a 98 E350 van on my Born Free RV. I'm swapping fluid and filter today. I bought both deep and shallow filters just encase.
I pulled the pan and since it's a 2 wheel drive, the filter in it is a shallow filter, short neck on the pickup tube. However, the pan...i'm not sure. It looks deep. I don't know if the PO swapped the pan and used the wrong filter.
Anyone help? The owners manual says 15.9 quarts.
Old Apr 15, 2018 | 10:28 AM
David7.3's Avatar
David7.3
Looks to me the standard E4OD trans, deep sump. They hold 12 quarts. I always start with ten and start and fill from there, it's easier to add than to remove and too much fluid will blow the tourqe converter seal right out. Be safe and smart. Hope this helps
Old Apr 15, 2018 | 10:55 AM
baddad457's Avatar
baddad457
If you want to do a complete fluid change, drain the torque converter too. There's a drain plug on the front of it you can access through a hole in the flexplate. It will hold about 4 gallons of fluid with the converter drained.
Old Apr 15, 2018 | 06:28 PM
serpa4's Avatar
serpa4
Thanks, the filter that came out was a short/shallow pan filter. I put in a deep filter. The pan went into place with no evidence of hitting the longer pickup tube. I also drained the TC, thanks for the tip.
Old Apr 15, 2018 | 09:17 PM
jeffreyclay's Avatar
jeffreyclay
What's this? No one is going to tell serpa4 that his transmission is going to grenade due to the fluid change? I've done the same thing he has done a few times and never had a problem. Sounds like good maintenance to me.
Klemhineycutt
Oct 28, 2018 10:27 PM
chetspencer
Oct 2, 2017 11:37 AM
Montync
May 11, 2016 05:25 PM
RojoStar
Aerostar
Apr 3, 2012 07:32 PM
mh5500
Dec 12, 2008 05:55 AM
