driveline vibration
Just noticed a periodic vibration about once every couple seconds while driving under load. Then coasting in neutral, a very steady vibration, strong enough to make the rear view mirror unusable. A search of the net brought up things like driveshaft out of balance, loose bolts on the driveshaft, worn U-joints, or worn wheel bearings. Being a 31 year old car with 170K miles, any of those is a possibility.
Checked the U-joints, and could not detect looseness. Can't check driveshaft balance, but no play at the transmission, and all bolts at the diff flange were tight.
Then checking wheel bearings, I grabbed the wheel on each side and tried to push them up and down, and find ever so slight motion. So the question is, is there any motion allowed?
I pulled the axles for a closer look at the bearing surfaces. Any opinions on how they look? Are they still serviceable?
left and right axles
Take your u-joints apart. I think you will find the issue. (based on how my '65 was with worn u-joints)
I found no detectable movements in the U joints, but I'll check them out anyway. thanks.
Having said that, the vibration you described is, imo (FWIW LOL) too severe to be wheel bearings. Having driven a Ford wagon to the point of having the bearing fall out in pieces when I took the retainer off, I can tell you it was very loud, but not much vibration. The failing u-joints made vibration. They will seem tight when things are all bolted up, but in my case the crosses were terrible, and most of the rollers were mia.
If it wasn't for the leaky diff cover, there was no need for me to take my rear end apart. The axle end seals seemed kind of stiff, and seeping a bit more than I'd like, so they're being replaced as well. One good experience
I'm thinking that I should replace the bearings anyway because of their age and mileage, and I have everything apart. But I broke a cheap puller trying to pull the first one, so I'll have to find something better.
One good experience from this is that when I serviced the rear end some 20 years ago, I replaced the factory lube, which had turned into a black goo, with Mobil 1 gear lube. Draining it now I see it's still a nice clear amber color. I'm sold on Mpbil 1.
