Which rims ....
Old Apr 14, 2018 | 06:17 PM
Ben Hartland's Avatar
Ben Hartland
Which rims ....
My 1972 F-250 has 8-lug/bolt rims. Trouble is they are split rims and no one will touch them. So I need a different set. What years of Ford 8-lug were compatible?
IDK if it makes a difference but some have mentioned an inner lip on some years.
Thank you,
Ben
Old Apr 14, 2018 | 06:58 PM
RichS2659's Avatar
RichS2659
F-250/350 SRW till 1998, and E-250/350 to 2013. DO NOT GET SUPER DUTY WHEELS as they are 8 x 170mm, not 8 x 6 1/2" pattern. These wheels are 16". Do not use 16.5" wheels as these are very obsolete and probably can't find tires. You can step up to 17" Dodge/Fiat Ram wheels or larger as tires could be cheaper. Only check to make sure the hub is the same size as your original wheels.
Old Apr 14, 2018 | 10:06 PM
HIO Silver's Avatar
HIO Silver
80s and 90s 3/4-ton Econolines are a good source... usually plenty of them in the yards
Dunno the cut-off year. Of course, bring a tape measure with ya to the salvage yards.
Old Apr 16, 2018 | 12:31 AM
351Cleveland C4's Avatar
351Cleveland C4
Can buy any number of aftermarket wheels too.
I recommend getting 17" wheels for better caliper clearance. 16" aluminum wheels can be tight and not allow for proper balancing weights.
Old Apr 18, 2018 | 10:39 PM
hjartland's Avatar
hjartland
Thank you all.
Thank you all. I never got a notification about your replies! I thought no one read this thread.
Great info!
BTW, Ford loves to change things around.
Old Apr 18, 2018 | 11:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Dunno the cut-off year. Of course, bring a tape measure with ya to the salvage yards..
8 lug wheels on a 6.50" bolt circle: 1975/2014 E250/350.
Old Apr 24, 2018 | 04:26 AM
mrpotatohead's Avatar
mrpotatohead
Found a 85 E-350 with dual rear wheels but it has 16.5's? It has decent later model radials so I think tires are still available for these. I'm gonna go look at them today.
Old Apr 24, 2018 | 07:17 AM
NumberDummy
You do NOT want to use DRW's on a truck with SRW's!
Old Apr 24, 2018 | 11:51 AM
hjartland's Avatar
hjartland
DRW VS SRW
I had the same thought when I scrapped a 1996 F-350. But they'd stick out so far that they'd block me from getting it up on the hoist.
but TY for looking.
Old Apr 24, 2018 | 07:32 PM
mrpotatohead
My truck has dual rear wheels. That was random.
Old Apr 24, 2018 | 07:34 PM
NumberDummy
But the OP has an F250. How many F250's came with DRW? N-O-N-E = NONE!
Old Apr 24, 2018 | 08:52 PM
hjartland's Avatar
hjartland
It's
It's all good guys. I have the needed info.
Thank you all again.
Old Apr 25, 2018 | 03:18 AM
Thipdar's Avatar
Thipdar
Thank you,
Ben
I went tire shopping for 16.5" tires and was astonished. It used to be that they were really common, and very much the "workhorse" tire. The only ones I could find were more than $400 EACH.
I'm not enough of a purist to pay for them.
I checked the junk yards and found a set of 5 rims that were 16". IIRC, they were about $125 for the set, and I had to drive about 70 miles round trip to fetch them.
Compared to buying the 16.5" tires, there was an immediate savings on the cost of the tires, and there will be additional savings the next time I buy tires.
That, and I don't have to take my pick-up to the Goodyear Commercial Tire Center in order to have them deal with the split rims. The last time I went there, they sold me a set of Firestones. The following Monday, those Firestones stopped the truck (panic stop), but the guy in the Toyota behind me didn't... and totaled my truck.
I think the "inner" vs. "outer" designation has to do with how the hub caps are held by the rim.
Old Apr 25, 2018 | 03:25 AM
hjartland's Avatar
hjartland
$400
$400 !? Wow. Glad 16s are an option. Good thing this is a Resto-Mod.
It's getting a 460 & E4OD. Big step up from 360 & C6.
I hope to spend $750 for a good set of tires, but not in the budget atm.
Old Apr 25, 2018 | 07:51 AM
mrpotatohead
The 85 E-350 that was supposed to have the acorn style lug nut wheels had the later model ones so I'm still looking myself.
