Which rims ....
Old Apr 25, 2018 | 07:52 AM
mrpotatohead's Avatar
mrpotatohead
But the OP has an F250. How many F250's came with DRW? N-O-N-E = NONE!
Take it easy old man, you shouldn't get so riled up at your age.
Old Apr 26, 2018 | 03:05 AM
Kurttb1's Avatar
Kurttb1
BOLT PATTERN GUIDE AND LUG NUT CHART FORD TRUCK 1969 F-250
This might be of some help for you, If you find this chart to be wrong about the '04 & Older F-250 please let me know, Kurt
Bolt Pattern Guide and Lug Nut Chart Ford Trucks
Old Apr 26, 2018 | 10:30 AM
351Cleveland C4's Avatar
351Cleveland C4
It is. 04 back was M14-2.0 just like the others.
Old Apr 27, 2018 | 12:11 AM
Kurttb1's Avatar
Kurttb1
ALUMINUM WHEELS for 1969 Ford F-250 ?
Someone had mentioned that 16 inch Aluminum wheels might not give enough clearance for the brakes?? Any comments?
Also I am looking at some Aluminum wheels for my 1969 F-250 Camper Special and they came off of a 2001 F-250. The chart says the bolt pattern and size of the lugs are the same.
From your experience do you think the chart is correct and
Aluminum Wheels for Ford F-250
agree that these Aluminum wheels would fit the bolt pattern and lug bolt size?
Old Apr 27, 2018 | 06:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Impossible!
1999 and later F250/350 wheels are METRIC!
8 lug wheels on a 6.50" bolt circle: 1948/52 F2/F3; 1953/96 F250; 1967/97 F350; 1969/74 E300; 1975/2014 E250/350; 1997 F250 Heavy Duty.
No such thing as a 1998 F250 H/D/350. No Econoline of any year has metric wheels
Old Apr 27, 2018 | 06:19 PM
351Cleveland C4
Super duty wheels will not work.
16" aluminum wheels CAN fit, but you won't have room for balancing weights on the inside. Best to go with 17" wheels.
Old Apr 27, 2018 | 10:56 PM
Kurttb1's Avatar
Kurttb1
17" rims for a 1969 F-250
Do they actually make 17" wheels with the 8 x 6.5 configuration? If so where to find them?
Old Apr 27, 2018 | 11:47 PM
RichS2659's Avatar
RichS2659
Yes, you can find them anywhere at tire stores or online. Or you can find stock Dodge/Ram 17" wheels. My son has a set on his 79 F-250 4wd.
Old Apr 28, 2018 | 12:08 AM
Kurttb1's Avatar
Kurttb1
17" wheels rims for 69 F-250
Thanks for the info. So Dodge has the same size bolt circle, what about the center hole do the Dodge standard rims fit too?
Old Apr 28, 2018 | 12:14 AM
RichS2659's Avatar
RichS2659
Same size, but measure for sure because I think Chevies use a smaller hub size, so just measure to be on the safe side.
Old Apr 28, 2018 | 12:20 AM
351Cleveland C4
Ford Econoline van used the eight on 6 1/2 bolt circle up until 2013
Old Apr 29, 2018 | 08:49 PM
Kurttb1's Avatar
Kurttb1
FOUND DODGE 17" RIMS from 2004 Dodge Ram
Hey Rich, Tomorrow I am going to pickup one of the wheels and then make sure it fits my 1969 F-250 Explorer Camper Special, Guy said they had a few scratches but hope they are not too bad will also ck that out.
According to online sources the Stock Dodge Wheels come with a 8 x 6.5 Bolt circle and a 120.9 mm Center Hole or 4.76 inches however, my Camper Special has that 1 ton rear end (I think). I am hoping the center hole will fit over the back Axle. If it does it will be super close, I'll post the results. Of course the other issue is the back spacing. I'm not sure I want to deal with having to buy spacers, any ideas?? Since they are 17" wheels according to other posts here I should have plenty of room for the brake calipers. These rims have 35's on all of them. My Truck has 35's on a 16.5 rim in the back but only 285x75Rx16 on the Front, When I try to put the wheels on the front I imagine I am going to run into problems with the tire size, Any comments are appreciated.
2004 Dodge Ram 17" wheels w 35's
Old May 24, 2018 | 06:20 PM
  #28
Kurttb1's Avatar
Kurttb1
Dodge Ram 2500 Wheel 17 x 8 fitment to Ford F-250 Camper Special
Presently on fitment of the 17" Dodge Wheels on the Rear of my 69 Camper Special.
The Dodge wheels are 17x8 and have a 6.25 inch backspacing,
the spoke rims on my truck are 10" and have 4.75 inch backspacing.
So I will need, 1.5 inch minimum thickness of adapters? Possibly 2"
I also received the lug nuts from the 2004 Dodge Ram 2500 with the wheels and I tried to screw them onto my studs and they are much bigger 9/16 -18
Also the holes in the Wheels are slightly bigger not sure if that matters but the Dodge Lug nuts have very large surface area compared to the Ford Acorn lug nuts
PICTURE INFO : Pic 1 THE Wheel sitting on the axle is not flush with the hub, the wheel thickness is 3/4 inch so there maybe 3/4 to 1" between wheel center and hub surface. Also, You can see the size of the
holes in the wheel are very large and the smaller stock Ford Acorn lug nuts may not work.
Pic 2 As you can see in the second pic the TIRE is hitting the truck Bed - (note the wheel center is as first picture not flush)
Last edited by Kurttb1; May 24, 2018 at 06:42 PM. Reason: more info about pictures
Old Jun 24, 2018 | 01:56 PM
  #29
hjartland's Avatar
hjartland
Good to
Good to know. Have you found a fix for this yet?
Old Jun 24, 2018 | 07:36 PM
  #30
Kurttb1's Avatar
Kurttb1
A buddy of mine just sold me a couple of 1 1/2" Wheel adapters. I am going to try them and see if they put the wheel out far enough.
