High beams
Apr 12, 2018 | 08:40 PM
High beams
I have a 1998 Mazda B4000 4x4 the high beams don't work I changed the switch on the collum can anyone help me with this?
Apr 13, 2018 | 07:08 PM
Do all the other exterior lamp functions work OK? Check fuse #12 (30A) located in the fuse box under the hood. Also check fuse #33 (15A) and fuse #4 (10A) and also fuse #8 (10A) that are located in the fuse box inside the cab.
Apr 17, 2018 | 07:30 PM
High Beams
I don't have a book for that do you have a diagram to help me thanks if you can help.
Apr 18, 2018 | 08:18 AM
Quote:
Originally Posted by
Buddy2424
Fuse Box Diagrams can be found in the Owners Manual...if you don't have the OM then maybe you can find one online for your 1998 B4000.
Also, I'm pretty sure - but I am not 100% certain - that the '98 Ranger OM would work for you as well, since they are essentially the same truck.
See:
http://www.fordservicecontent.com/Fo.../98ranog1e.pdf (Starting on page 95).
Apr 18, 2018 | 11:12 AM
Online owners manuals (no cost) have been available for years at the Fleet Ford website.
Apr 18, 2018 | 09:49 PM
High Beams
Hi thanks I will try a relay under the hood and the others I will get back with you with the info.
Apr 19, 2018 | 09:12 PM
High Beams
Hi you are a life saver got HIGH BEAMS thanks for all the help. And I will save the link you sent for the manul.
Apr 21, 2018 | 09:28 AM
What was the apparent problem/cause for the lights to not work?
Apr 22, 2018 | 01:09 PM
High Beams
It was a fuse that was not in 33. Thank you for everything
jedidiah
Electrical Systems/Wiring
Mar 3, 2020 10:04 PM
JOEPICKUP
May 14, 2012 09:37 PM
preppypyro
1997 - 2003 F150
Jan 29, 2005 09:43 AM
89f150
May 2, 2001 12:59 PM
