1960 wiring help!!
Old Apr 12, 2018 | 03:05 PM
Bri Heather's Avatar
Bri Heather
As soon as i got the truck and saw the wiring i only fitted a battery when i needed to move it, the wiring worried me that much!
ive ordered the wiring diagram from classic car wiring and will methodically go through it all.
Old Apr 16, 2018 | 10:44 AM
Bri Heather
Help needed
can anyone post a simple diagram for me to wire this up correctly please.
Old Apr 17, 2018 | 02:02 PM
G-Force junky's Avatar
G-Force junky
The red wire should go to a fused power source.
The yellow wire should go to battery positive.
The brown wire should go to alternator/generator light.
Old Apr 26, 2018 | 01:21 PM
Bri Heather
Thanks for all the help, how hard is it to remove the wires from the connectors? has anyone replaced wires this way.
Old Apr 27, 2018 | 08:22 AM
Byrd.Dog's Avatar
Byrd.Dog
I don't know of a way to replace the wires into the actual bulkhead connectors. Best bet would be to splice in new wires & try to cover up with heat shrink best you can. I completely re-wired my 60, but I used one of the Painless Wiring universal harnesses. My only complaint is that there is no option for a bulkhead connector - all wiring has to run out a hole in the firewall. From your pics, it doesn't look like the wiring is butchered beyond repair. Unless you're worried about a "Professional" look, I'd go through & clean up loose wires & sketchy splices, then wrap with some kind of loom. I got an assortment of stuff called powerbraid from summit that works pretty well.
Coastal68
28
Nov 14, 2015 07:02 PM
F100Jay
Apr 6, 2015 02:51 AM
robjef
Electrical Systems/Wiring
Oct 24, 2010 04:06 PM
jinserra
Jan 31, 2009 05:30 PM
55fordtruck
Apr 26, 2004 09:59 PM
