Converting ignition system
Old Apr 10, 2018 | 08:18 AM
ajg596's Avatar
ajg596
I want to eliminate the external box and ballast. I know I need a 12v coil. Does it need to be internally regulated and any suggestions on a good coil to use? Also do I need to do anything to the distributor and what do I do as far as eliminating the voltage regulator box on the fender? I’m not sure where to start.
Old Apr 10, 2018 | 08:55 AM
JessyJ's Avatar
JessyJ
Why do you want to do this?The stock setup is the best it can be.As for the volt reg do an alternator upgrade with a internal reg.
Old Apr 10, 2018 | 09:02 AM
ajg596's Avatar
ajg596
Higher voltage, hotter spark. Setting up for 2 step launch control
Old Apr 10, 2018 | 09:57 AM
LARIAT 85's Avatar
LARIAT 85
So, you are going to drag race your full-size Ford pickup truck?
Old Apr 10, 2018 | 10:04 AM
ajg596's Avatar
ajg596
high hp motor. Eliminating points distributor. Resistor was just to make points last longer from what I’ve researched. I need to know if I can just remove the resistor with a new 12v coil?
Old Apr 10, 2018 | 11:02 AM
Filthy Beast's Avatar
Filthy Beast
What year/type engine, trans, etc?
If your engine is already "built" to some extent, what do you have for her innards?
Just by eliminating the stock ignition setup ain't gonna get you any increase in ponies or torque.....
The resistor wire has nothing to do with making the points last longer and everything to do with helping an OEM coil (or the same type aftermarket coil) not fry on you. It limits the running voltage to ~ 9VDC.
Yes, there are coils out there made to run on 12 VDC - eliminating the resistor wire. Can't tell you what brand, make etc. though.
Ok, so, say now you've eliminated the ballast resistor wire circuit......Now what? You think you're going to have a Johnny Go Faster vehicle now?
Old Apr 10, 2018 | 12:00 PM
bigreed91's Avatar
bigreed91
I didnt think dents had point dizzys, eary models? I'll be eunning a stock duraspark with msd 6al ignition. And +1 on the 3g alternator upgrade.
Old Apr 10, 2018 | 12:17 PM
LARIAT 85's Avatar
LARIAT 85
Unless you are planning on spinning your "high hp motor" in your pickup truck past 6000 RPM, an MSD ignition will gain you nothing over the stock DuraSpark ignition.
Old Apr 10, 2018 | 12:25 PM
Filthy Beast
Agree completely. Well said, LARIAT.
Old Apr 10, 2018 | 12:30 PM
Tedster9's Avatar
Tedster9
Can say the same thing about a standard points ignition too for that matter. It is nice not having to futz with them though.
Be careful removing any ballast or resistor in the primary ignition circuit. They aren't/weren't just to prevent burning up points. Excessive current flow will burn up ignition coils and electronic modules too if they aren't designed to take it. They talk about voltage drop in troubleshooting diagnostics but the purpose of the ballast resistor is to reduce the amps in the circuit and later solid state ignitions used them as well.
Old Apr 10, 2018 | 01:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I didn't think dents had point dizzys, early models?
1973 has points, as do some 1974/75's.
DuraSpark electronic ignition was introduced in 1974, but not all vehicles came with it until 1976.
Old Apr 11, 2018 | 12:26 PM
Filthy Beast
Originally Posted by Tedster9
.Be careful removing any ballast or resistor in the primary ignition circuit. They aren't/weren't just to prevent burning up points. Excessive current flow will burn up ignition coils and electronic modules too if they aren't designed to take it. They talk about voltage drop in troubleshooting diagnostics but the purpose of the ballast resistor is to reduce the amps in the circuit and later solid state ignitions used them as well.
I would agree with you on the current limiting aspect of the resistor wire but the service manual doesn't have any troubleshooting diagnostics for correct/incorrect current flow.
I suppose one could do the math using Ohm's Law to find acceptable amperage in this resistor circuit, presupposing all is well in the ballast resistor circuit and compare it to a presumed faulty one......but, why when we already have resistance and voltage diagnostic parameters? Two out of three ain't bad......
Old Apr 11, 2018 | 12:59 PM
Tedster9's Avatar
Tedster9
That's because they don't need to, if the primary circuit has the proper resistance the current flow will take care of itself. I was just trying to explain, probably not very well, that the amps is what's important here.
Old Apr 11, 2018 | 02:02 PM
bigreed91's Avatar
bigreed91
i have the msd just sitting in my shed, it was planned for another build that got sold so im only gonna use it for no reason other than i can and i think it'll look cool. Better than it collecting dust.
Old Apr 11, 2018 | 02:06 PM
Filthy Beast
No problems, Tedster, got you covered on all that.........
