Identify Tube
Old Apr 9, 2018 | 01:35 PM
arthall's Avatar
arthall
Identify Tube
I recently bought a '53 F100 with the flathead V8. This tube was in the bed. It looks like a drain of some sort. Can anyone help me identify what it is and where it goes? Thanks.
Old Apr 9, 2018 | 01:40 PM
CharlieLed's Avatar
CharlieLed
Looks like an exhaust pipe for a motorcycle. What is the diameter of the pipe?
Old Apr 9, 2018 | 01:50 PM
arthall's Avatar
arthall
Hmmm. Maybe it's not part of the truck after all. It has a 1 1/8 ID and a 1 1/4 OD.
Old Apr 9, 2018 | 01:55 PM
Mixer man's Avatar
Mixer man
I'll wager it's a bike exhaust for a forward cylinder.
Old Apr 9, 2018 | 02:04 PM
Indybeer's Avatar
Indybeer
Appears to be something like I have on my truck
Old Apr 9, 2018 | 02:30 PM
rico56's Avatar
rico56
At first it looked to me like a tube for an oil-dipstick, maybe from a transmission, but the diameter of 1 1/4 is to large for that.
So it's likely a exhaust tube from a bike.
Old Apr 9, 2018 | 02:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It's either an engine oil or A/T dipstick tube. The bracket attaches the tube to the exhaust manifold.
Old Apr 9, 2018 | 02:48 PM
arthall's Avatar
arthall
What year and what engine do you have? Mine is a '53 239 cu in flathead. What does that pipe do on your truck? Thanks.
Old Apr 9, 2018 | 03:04 PM
Indybeer's Avatar
Indybeer
I have a 223. My tube is less than 1" But it sure looks the same.
Old Apr 9, 2018 | 03:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's the crankcase vent tube for a V8. Kind of an unusual one, tho. Usually two pieces. Most turn at the oil pan and go horizontal, then down at a 45. Others are as shown below
Old Apr 9, 2018 | 04:03 PM
ReForder's Avatar
ReForder
That tube shown by Indybeer (and in the diagram) is a "road draft tube" for crankcase ventilation (it essentially dumped oil residue and vented oil "gasses" under the car while you were driving. ie: it's the early PCV system but hippies spontaneoulsy combusted when they saw it, so they had to get rid of it and put proper PCV systems on engines.
But that tube could be one but no idea if it's for your engine or not.
Old Apr 9, 2018 | 04:12 PM
arthall's Avatar
arthall
Identify Tube
Thank You! Mystery solved! Great picture - where did you find that?
Old Apr 9, 2018 | 05:06 PM
arthall's Avatar
arthall
Identify Tube
Thanks for the info. I learned something today.
Old Apr 9, 2018 | 07:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's in the 48-56 Ford Parts CD, available here: https://www.hipoparts.com/1948-56-fo...ts-catalog-cd/
Old Apr 9, 2018 | 07:54 PM
arthall's Avatar
arthall
Thanks, I have one on order.
