Cyl heads
Old Apr 7, 2018 | 03:44 PM
catimann's Avatar
catimann
Cyl heads
I found some cyl heads that are as you see. My motor is a C1BA. Will these fit on the 50-51 motor I my motor is a have? See https://www.ford-trucks.com/forums/1530976-tune-up.html
Old Apr 7, 2018 | 10:54 PM
catimann's Avatar
catimann
Well I bought them based on this web site page. Flathead Specifications: 1949-53 V8
All the bores are the same and I would assume the rest is, have not looked yet. If not I am sure some crazed Merc nut is out there at some point.
I was.
Old Apr 8, 2018 | 10:57 AM
tacomacream's Avatar
tacomacream
I think that these EAC heads will fit on your flathead engine. They are similar to the EAB Ford. I have a set of those on a 24 stud engine.
There is a lot of info on the flathead Ford engines:
https://www.google.com/search?client....0.gvixmdyt0kM
Old Apr 8, 2018 | 03:10 PM
51504BAT's Avatar
51504BAT
Heads
If I'm not mistaken EAC heads are Merc heads and if used on a 3 3/4 stroke engine the result is lower compression. The EAB heads were higher compression compared to 8ba heads. The 8rt truck heads were the lowest of them all from what I understand.
Old Apr 12, 2018 | 11:20 AM
1952 Ford Coe's Avatar
1952 Ford Coe
They will work. My motor has a ford and mercury head on it. One of those "I'm going to fix eventually".
1952henry
53
Aug 5, 2024 12:24 PM
WhatsAChevy?
Mar 17, 2017 07:07 AM
Nicholas B
Jun 14, 2015 09:28 AM
pond digger
Dec 7, 2007 11:47 AM
backwoodspuller
Oct 12, 2006 10:06 PM
