Brake pedal issues
Old Mar 23, 2017 | 07:21 PM
Taylor Doyle's Avatar
Taylor Doyle
Brake pedal issues
I am having issues with my brake pedal feeling sloppy, or weak seems like it goes all the way to the floor to get any response from the brakes. Alittle info, I just changed my front disc brake pads, and also all the springs and shoes on both rears.. I DID NOT remove the calipers or any brake lines. I would not think one needed to bleed the brakes if you changed just the springs, shoes, and pads, or am I wrong? Which I am alot... a little help from the great knowledgeable people here would be awesome!
Old Mar 23, 2017 | 07:58 PM
cmanka28's Avatar
cmanka28
I'd check the adjustment on the rear brakes, you want them to have a little drag on them
Old Mar 23, 2017 | 11:30 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Sloppy..like spongy? Spongy is air in the system, bleed them. Bleed off of pedal could be bad master cylinder or power brake booster.
Old Mar 24, 2017 | 12:30 AM
Tedster9's Avatar
Tedster9
This will do it too, and it feels a lot like air in the system or mushy low pedal. Crank up the adjusters as tight as they will go and depress the pedal a few times to center the shoes and parts, and then back them off. Takes all the "slop" or clearance out in the system. If you do need to bleed the system, it helps to bleed while the adjusters/shoes all the way up tight as far as they will go.
Old Mar 24, 2017 | 07:46 AM
brian1080's Avatar
brian1080
Definitely check your adjusters. I've spent months arguing with my brakes, new parts, new parts again, back to old new parts. What I finally found was my rear adjusters were way out, so my pedal went to floor before they engaged. Tightened the adjusters and now I have brakes.
Diesel Reaper
Apr 25, 2012 08:47 AM
lorolr
13
Feb 14, 2012 09:54 AM
jxer00
Jun 10, 2007 04:52 AM
thedettras
Mar 30, 2005 12:05 AM
Sycostang67
Feb 16, 2005 01:11 PM
