Were you able to get the broken piece out?
I was able to get mine at local Mom and Pop autoparts store. Its a simple screw in fitting. Justa couple of bucks,maybe.
Heater Tube - Ford Part # E8TZ-18B402-C, Motorcraft Part # KT81. Still available from Ford and various retailers.
Also look at Motorcraft # KT84. The online catalog lists the KT81through 94 and the KT84 for 95-96, but neither look quite like what you have, although I bet the KT81 is what you need.
I haven't had to replace one before. If the base swivels then it should be pretty east to replace, but if it doesn't you will have to pull a lot of stuff out to replace it.
I re-read my posts. I was able to fix mine easily. The top nipple that broke on yours broke on mine.I was able to unscrew that ?1/4"? nipple and screw in a new one. 5 minute fix.
Heater Tube - Ford Part # E8TZ-18B402-C Motorcraft KT-81. Still available from Ford and various retailers.
