2002 Explorer stops running
Old Apr 3, 2018 | 05:33 PM
Graygeorge's Avatar
Graygeorge
2002 Explorer XLS, 4.0L, 4x4, 188,500 miles just quits running after 20, 10 or 5 miles. No CEL. Starts back up after maybe a 4-5 minute wait. Anyone had an issue like this that can point me in the direction of problem. I have replaced the fuel filter and checked for codes.
Old Apr 3, 2018 | 09:22 PM
steve(ill)'s Avatar
steve(ill)
I had that 3 months ago..... fuel pump died... when you slam the door / etc, it bumps the pump a bit and it starts turning again..... next time it will not start, get under the hood, push the "Schrader valve" on the fuel rail and confirm that there is no gasoline in the fuel line.... next time you turn the key on- off a couple times, and slam the door, see if you have pressure in the line then.
Old Apr 3, 2018 | 09:23 PM
steve(ill)'s Avatar
steve(ill)
each time you turn the key "ON", not to the start position, the fuel pump should run for 3 seconds and build up pressure in the fuel rail.
Old Apr 4, 2018 | 08:06 AM
Graygeorge's Avatar
Graygeorge
Thanks Steve
Old Jul 16, 2018 | 06:06 PM
Graygeorge's Avatar
Graygeorge
Replaced fuel pump and fuel filter. Runs fine now.
Murf-150
2009 - 2014 F150
Feb 26, 2019 08:25 AM
WoomaHodal
Oct 7, 2011 05:55 AM
ajsperr
Oct 23, 2009 08:51 PM
dcducks1
Dec 23, 2002 04:31 PM
