WiFi dongle for the OBD II port and Torque Pro. Will do most of what Autoengenuity and the other computers will do (like buzz test), and you can watch all the data the computer monitors in real time....
I couldn't get Torque to work for me for the Buzz test, but I did have success using Car Guage pro. I did get the following codes:
P0603
P0478
P0542
P0478 is the one I'm going to look at right away with the Exhaust Pressure tube and sensor.
P0603 is probably because I just changed my batteries
P0542 not sure why this is here. I removed the AIH a while ago and installed the RiffRaff Code Eliminator. I'll see if it is bad.
Buzz test performed and it passed. I noticed no variation in the sound between all 8.
I will do a contribution test when I get the chance this weekend.
Here is some information is you want to continue trouble shooting you injectors...Maybe it could help a little.. I don't remember how the shop came down to telling me I had a bad injector.
