65 Steering Box options, Manual
Old Apr 1, 2018 | 11:02 PM
1965GTFB's Avatar
1965GTFB
I've tried using the search with no luck.
Question is:
1965 F100 steering box rebuilt, replace, or?
It seems as though the 65 manual steering box is a one year only, not many parts available situation. Even basic parts like seal kits.
My box is getting to be as sloppy as a 13 year olds room.
Are there parts, replacement boxes, rebuilders out there?
Or even power conversions like what Borgeson makes for other applications(I've installed one of those on a 65 Mustang for some one).
Old Apr 2, 2018 | 12:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 1965GTFB
Question is: 1965 F100 steering box rebuilt, replace, or?
There is no seal kit.
C5TZ-3504-D .. Manual Steering Gearbox / Obsolete
1965/72 F100/250 2WD; 1967/72 F350.
All the parts are obsolete, but some are available NOS .. You could send it to Red Head Steering Gears in Seattle and have it rebuilt.
Upper pic = C5TZ-3504-D: 3524 is the steering shaft; 3552/3571 are the steering shaft bearings and races; 3575 is the sector shaft; 3576 are the sector shaft bushings.
3581 is the sector shaft gasket; 3591 is the sector shaft seal, 3783 is the steering shaft seal.
Old Apr 2, 2018 | 01:38 AM
1965GTFB's Avatar
1965GTFB
Is Red Head good? I've read differing reviews.
The #s on the box on the truck are: on Tag HDC B 4L 19B. Need to scrape off some grease to read the #s on the case and pitman arm.
I have another box with a pitman that I picked up several years ago. The #s on it are: on Tag HDC B 5JO 1B 1, on case C5TA-3550, on pitman arm C5TA-3590A then maybe -69 on the end that's hard to read.
Figuring it's the same box as what is on the truck now. I plan on pulling the box off the truck and doing some type of okie scientific testing with a dial indicator on both to see which box has less play.
I know from the Mustangs I've built that those use NLGI #1 grease, thick enough to not run out like gear lube and not as thick as wheel bearing grease that will stick in the corners. Same grade, NLGI #1 for a F100?
Old Apr 2, 2018 | 06:39 AM
NumberDummy
HDC-B = C5TZ-3504-D Steering Gear / C5TZ-3590-A = 1965/66 F100/250 2WD Pitman Arm
Old Apr 2, 2018 | 09:26 AM
TA455HO's Avatar
TA455HO
Lead Gopher
I've driven down to RedHead Steering in Auburn, WA a few times since they are only about 30 minutes or so away from me. It is a fairly small operation with about 10-15 employees total. They seem well organized and do a nice job from what I have seen, but like any business they can't please everyone.
Chad
Old Apr 2, 2018 | 09:31 AM
PROSTOCK's Avatar
PROSTOCK
I put a read head on my Excursion and just recently on my '65, both have been excellent, very helpful customer service. Not cheap.
Old Apr 3, 2018 | 07:33 AM
ssandirene's Avatar
ssandirene
I have one I took off my 65
if only you were closer
Old Apr 3, 2018 | 10:54 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Another option for a rebuilder in North Dakota being discussed in the 1967-1972 forum.
https://www.ford-trucks.com/forums/1...-gear-box.html
Chad
Old Apr 8, 2018 | 07:51 AM
User 71024's Avatar
User 71024
I also have one I don't need on my '66 F-250 4x2 parts truck. Let me know if you get in trouble. CapeCanal@comcast.net
78madmax
Apr 23, 2015 01:52 AM
Steve
WTB - Parts & other
Jan 2, 2015 12:18 PM
brenjimin
Oct 24, 2013 11:39 AM
lonelyford4x
Sep 20, 2004 06:18 AM
camperspecial65
18
Jun 10, 2004 10:06 AM
