Misfire
Old Apr 1, 2018 | 04:57 PM
Kenneth Spivey's Avatar
Kenneth Spivey
Misfire
Ok so after fixing those cables truck ran great for a few days. Then started running rough and dieing. Had rocker stud break again replaced that and still runs rough. Missing pretty bad. When you floorboard the gas petal it seems like engine dies or cuts out but when you release it comes back. If anyone has a clue where to look on this it be awesome. Thanks
Old Apr 1, 2018 | 07:59 PM
Franklin2's Avatar
Franklin2
Sounds like a fuel delivery problem. When you floor it, you re introducing a lot of air, there should be fuel to go along with it. If no fuel, it coughs and sometimes it will backfire through the carb and try to stall. Close the carb cuts all that air off and it reverts back to running ok.
Old Apr 1, 2018 | 08:09 PM
Kenneth Spivey
So maybe a fuel pump problem? Cause it has a new rebuilt Carter carb on it.
Old Apr 1, 2018 | 08:26 PM
Franklin2's Avatar
Franklin2
I just came across your other thread where you had electrical problems. Do you have a good blue spark? Make sure you have about 8 or 9v at the coil + when the engine is running.
Old Apr 1, 2018 | 08:49 PM
Kenneth Spivey
Ok I'll check it with a meter tomorrow it's to dark now. The air issue made sense. Because it does sound like it's blowing air trying to whistle.
Old Apr 1, 2018 | 11:54 PM
kr98664's Avatar
kr98664
Are the new misfire symptoms the same as when the truck was previously running poorly?
Old Apr 3, 2018 | 10:19 PM
Kenneth Spivey
No this time it's different. As above comment stated when you floor it the engine sounds like it cuts out and sounds like someone blowing air learning to whistle. Let off gas and motor comes back.
Old Apr 4, 2018 | 12:44 AM
kr98664's Avatar
kr98664
Okay, thanks. I had been wondering if the root cause of the original misbehavior had somehow returned, but that doesn’t seem to be the case.
Old Apr 6, 2018 | 05:21 PM
Kenneth Spivey
Ok Franklin2 I checked that voltage it was at 2.4 nowhere near where you said it should be. I also noticed while trying to test it slight movement of wires would cause truck to die. Once truck died I wiggled slightly to see what it would do and seen slight arcing. Tested my coil and it's safe. So now where do we go from here? Replace the electrical plug?
Old Apr 6, 2018 | 08:05 PM
Franklin2's Avatar
Franklin2
Sounds like a good idea. They sell the horsehoe coil connectors at the store, and they sell the ones for the square coils also, I just replace that one on my 86 ranger.
Old Apr 6, 2018 | 08:27 PM
Kenneth Spivey
Ok. I found the duraspark ignition system online for $150. Would it be better to just replace the complete wiring system? Or could I get by with just that horseshoe connector?
Old Apr 6, 2018 | 08:30 PM
Franklin2's Avatar
Franklin2
I have forgotten what engine and what you are working on? I have never seen a complete system for sale, do you have a link to it? If you had a computerized six, you might consider replacing the whole thing.
Old Apr 6, 2018 | 08:52 PM
Kenneth Spivey
1981 300 l6 not computerized. And I just googled duraspark wiring harness. Summit racing sells one.
Old Apr 7, 2018 | 07:41 AM
Franklin2's Avatar
Franklin2
If the problem is at the coil, why not spend $3.95 at Autozone and see if that helps it. Part number 252. Looks like they may have to get it from their warehouse.
Old Apr 7, 2018 | 07:44 PM
Kenneth Spivey
Yeah I'm finding everyone locally has to order it. And I definitely hope that's the only other problem. If not I may just go through the whole wiring system with a new harness if I can even find a complete harness for the whole truck. Cause let's face it tracking down short circuits isn't a fun task.
